Old 09-09-2004, 10:18 PM   #1
72bigblock
2" body lift
i am thinking about putting a 2" body lift on my 72 3/4 4x2. good or bad???
72bigblock is offline   Reply With Quote
Old 09-10-2004, 08:01 AM   #2
72bigblock
ttt
Old 09-10-2004, 08:52 AM   #3
drink2mny
drink2mny's Avatar
Can I ask why??
Support The Board
drink2mny is offline   Reply With Quote
Old 09-11-2004, 10:22 AM   #4
72bigblock
i need to get the body up to get my push bumper off the ground wiht out blocking my headlights.
Old 09-11-2004, 02:07 PM   #5
2wdBlazer
The Blazer King
2wdBlazer's Avatar
I run a 3 inch on my Big Blazer. Works well and never had a problem.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 09-13-2004, 08:02 AM   #6
72bigblock
ttt
Old 09-13-2004, 08:27 AM   #7
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Hmm, can the push bumper be modified? Weigh that against the mods for the body lift. Fan shroud relocated, steering lengthened slightly, shifter shortened and the trow of the shifter could hit the cab, auto or manual linkage needs to be lengthened. Check speedo/e-brake cables, brake lines, fuel line for inteference. Make sure you have enough play in wires for lights, etc... Make sure rad hoses not in a bind from radiator going up 2".
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 09-13-2004, 10:11 AM   #8
poff
I just did a 1" body lift and it wasn't too bad. Had to move the fan shroud and extend the clutch linkage. The steering was OK. Only issue is the lower radiator hose is rubbing the inner fender, still working on a solution. Can you notch the bumper for the lights?
'70 K-20 San Diego, CA
poff is offline   Reply With Quote
Old 09-14-2004, 10:08 PM   #9
72bigblock
what brand should i get?
Old 09-16-2004, 01:19 AM   #10
chevy69er
I was also thinking about doing a body lift and the only thing i was questioning was my clutch linkage.What would be the best way of going about this?As for a good brand of body lift...i've heard good things about performance accesories and that is available through four wheel parts.
1969 C-20,383 stroker,sm465,custom long travel front suspension,4 wheel disc brakes,35" pro comps...mods under way include: 4x4 conversion,and custom bumpers.future mods include: gear vendors od unit,and relocation of fuel cell.
chevy69er is offline   Reply With Quote
Old 09-16-2004, 01:53 AM   #11
poff
Offroad designs in Colorado makes a one inch body lift for Blazers. www.offroaddesign.com The web page lists '73-'87 only but my buddy bought a set for his '69, just call and they set you up with what you need. You can buy as many as you need if you have a truck. Since I have a truck and need alot more "pucks", one of my buddys made mine on the lathe out of aluminum.
As far as clutch linkage, I just cut it in half, found some tubing to slip over the rod and welded it back together. I extended it about 3/4". Also made brackets to space the fan shroud down 1". Electric fans eleminate this problem also. I also got a 1" spacer for the thermostat housing. I actually got it so the thermostat housing would clear my temp. sending unit since my new vortec engine had too small of a hole in the head. Just turned out to help the upper hose be in the stock location. Only thing I haven't fixed is the lower hose rubs the inner fender a little more than I'd like. Looks pretty easy to fix but I have been concentrating on building a front bumper which now that i think about it, looks like the stock one would have been a tight fit.
