Fellas , I have lost the post that covered the required connections for using an inernally regulated alt. on my 67.
How are the old regulator wiring harness connections rerouted? Seems like you connect 1 to 3 and 2 to 4 but the photo looked like 1 to 2 and 3 to 4. I should have posed this question while the post was current...now i can't find it in the archives. Thanks for any help!
1967 C10 Short,Step 283\1460 Holley HEI Ign. Borg Warner T56 6 Speed! A-1 Electric life pwr windows PS,PB,Tilt 275\60R'S on Alum Mags all around Vintage Air A\C Grey cloth Buckets ![]() |
![]() Join Date: Mar 2003
You don't have to do that. Remove the blue and white wires completely. Extend the brown wire to connector #1. Loop a red wire from connector # 2 to the battery terminal. Hook up the main charge wire to the battey terminal also. Dun.
Thanks KW
That's a much simpler plan...even I might be able to do this conversion!
Thanks again, Bill
The oddest Todd around
Here is the link.
http://67-72chevytrucks.com/vboard/s....php3?t=111296 |
Thanks Todd! you are the man!
Now excuse me I gotta go to Advance and be rid of this archaic charging technology
The search function comes in handy again!
Either the old alt or voltage regulator went out today. Went to the parts store and the guy knew the part# off the top of his head so I don't know what the alt actually fits, but it bolted right up. Changed the wiring as explained by kwmech above and shes purring like a kitten. ![]() I take it the old black ground wire that went to the old alt has no function any more? Thanks guys for making this board such a great rescource! |
