09-10-2004, 10:27 AM | #1 |
Rear end question
I have 3:73 non posi in my truck right now. I also have 2 parts truck that each have 3:08 (i believe) non posi in them. Would it gain me much on highway travelling to swap out the entire rear end to the 3:08 ? At 60 mph my engine has to be running at about 2800 rpm or higher right now. I am running the original saginaw 3 speed as well. I plan on swapping out the tranny in a couple years, but was wondering about the rear end swap for now
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
09-10-2004, 10:53 AM | #2 |
YES IT WILL.... YOU SHOULD SEE A LITTLE BETTER THAN 20% REDUCTION IN YOUR R.P.M.s AT HIWAY SPEEDS. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
09-10-2004, 10:54 AM | #3 |
67 is sold
You should see an increase in MPG going from the 3.73 to a 3.08
If you tow anything of size frequently, I'd stick with teh 3.73. |
09-10-2004, 11:04 AM | #4 |
I don't haul much with this truck, so this looks to be a good swap for me. I just want something that doesn't run so high on RPM's when we go to other surrounding towns for shows and making runs to the cabin on weekends. Looks like I may have to set aside a weekend to swap out the rear, install the lowering blocks and cut the coils up front. I have 500 sq ft of laminate flooring to lay this weekend so I won't have time for truck play time
09-10-2004, 11:20 AM | #5 |
its all about the +6 inches
How does that sound to you? 350/TH350 non lock up, 3.07 rear gears, ans 28-ish inch tall rear tires. |
09-10-2004, 11:24 AM | #6 |
I can actually hear myself fart in the cab at those rpm's Andy Right now tho, she's damn loud
09-10-2004, 11:26 AM | #7 |
Andy, buy some gas, man. Hey Tim, maybe Shawna doesn't want to hear you fart.
Silence is golden, duct tape is silver. - Scott |
09-10-2004, 11:28 AM | #8 |
Parts and more parts
Let me tell you a story about a little truck that we own. The truck is an 86 chevy, with a 350 engine, a 700 R4 tranny and 3:73 gears. It used to have 3:08 gears and the rpms were around 1900 on the highway. Sounds good doesn't it? Well the problem was that the truck's gas mileage was lousy with the 3:08 gears (12.5 mpg MAYBE) and the performance with the truck at 1900 was sluggish. The cruise control was constantly kicking down when you got into any kind of hills. I guess if you live on the flatlands---no problem. We put a 12 bolt 3:73 posi unit under the truck and the gas mileage went up to 15 mpg and the engine performs great, even when the cruise control is engaged. The 350 engine has a power curve that is predominant around 2100 to 2700 RPM and that is where the engine will become really efficient. The truck now runs at 2500 RPM at 70 mph and pulls real strong to get into traffic. Every person for their own choice, but a little kick is worth the fuel to me. I really do hate an anemic truck that couldn't get it's a$$ out of a peterbuilt's way. I also have an 84 GMC pickup with a 383 stroker and the same tranny and rear end. It is getting a good 15 mpg with a 400 hp motor, that is why we did the 86 with the 3:73 gears.
09-10-2004, 11:32 AM | #9 |
Very good points there...however, we are dealing with non overdrive vehicles here, so that is a non-issue.
Tim...if you can't hear your fart on a vinal seat...even at 3000 RPM, then you ain't pushing hard enough. No joke, I made one audible on the freeway with open headers. My passenger was about to punch me. |
09-10-2004, 11:43 AM | #10 |
ANDY ... I KNEW A GUY WITH A V.W. DIESEL RABBIT THAT GOT 50 MPG. (I'M NOT SURE WHAT GEARS HE HAD) BUT I GUESS THIS ISN'T AN ISSUE EITHER. JOHN
09-10-2004, 11:50 AM | #11 |
LOL! Very good point.
I had a hopped up 86 civic Si that got about 46 - 48 on the open road...only if I kept it below 80 though. That too...is probably a non-issue. |
09-10-2004, 11:50 AM | #12 | |
09-10-2004, 11:59 AM | #13 |
Now Shawna...I'm sure you could find something to plug up the leak.
09-10-2004, 12:00 PM | #14 |
yeah but then I'd build up to much back pressure and take out a window
09-10-2004, 12:06 PM | #15 |
I don't think that swap would be worth the effort to me. Will lower your rpms, but don't expect miracles on the fuel mileage. Just my two cents.....
09-10-2004, 12:10 PM | #16 |
Dean...I kinda agree with you on that. What ever you do save on the open road, you'll burn in town trying to get her rolling.
Onless you fly on the freeway more often than the surface roads. |
09-10-2004, 12:27 PM | #17 |
Watch out for your cornhole !
Dubie, my 454 truck had 3.73 gears in it. I could not make myself drive at speed on the freeway. 70 miles per hour was too much.
I traded a board member straight across for a 3.08 rear. My mileage increased 5 miles per gallon (up to 12) on highway driving. I have actually experienced what pieceparts has on an overdrive vehicle though. My 83 truck came with 2.73 gears and an overdrive. The mileage was horrible. When the 700 went bad, I replaced it with a non overdrive Th350 trans. The mileage actually increased without the overdrive because the engine didn't have to work as hard at highway speeds. For your 3 speed truck though, 3.08 will make you a happy man.
09-10-2004, 12:34 PM | #18 | |
Born To Lose Club
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Brian Smith - "Born To Lose" 1969 Chevrolet K10 LWB Fleetside - Proud Owner For 20 Yrs - 1 of 208 Built & Sold In Canada! - 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's. 1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 2 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds 2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 15 Yrs - 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's. 2008 Yamaha Raptor 700r - Proud Owner For 13 Yrs - ITP Mud Lites. 2015 John Deere 1025R - Proud Owner For 6 Yrs - 24HP Diesel/H120/54D/260B/SB1154. |
09-10-2004, 12:53 PM | #19 |
67-72 Addict!
Tim, I would personally stay with 3:73's for the fun factor!. If you really plan to do ALOT of highway driving then that's a reason to consider. If you had a torquey Big block then it might not be as noticeable, but with the current 350 the launchability will probably be felt. My 2 cents.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
09-10-2004, 12:54 PM | #20 | |
09-10-2004, 01:30 PM | #21 | |
Yeah this truck can really launch when you dump the clutch on it and i kinda like that feeling. I am toying with the idea of a T5 tranny swap so I gain some OD and that in turn would help get the rpms down. But seeing how my budget is spent on the truck, I kinda have to wait. Just thought if the rear end swap was worth it, I would do that for the short term. The truck is mainly used for around town cruising so the 3:73's work great for that. I'll just have to decide whether all the work involved in swapping the rear end out is gonna be worth it for me right now. And seeing how the truck is going to be rolled into the sister in laws garage in 3 or 4 weeks for the winter, I may run out of time for big jobs like this. It's gonna hurt to have to put the truck away until May 2005
09-10-2004, 02:15 PM | #22 | |
I wouldn't use the T5. The strongest version in stock form can only handle 305 foot pounds of torque. Your 350 should be there...or at least close. When you add in the factor of a heavy truck, that just ups the scatter factor.
There is a reason the T5 was never offered behind anything bigger than a 305. |
09-10-2004, 02:20 PM | #23 |
maybe time to search for a Muncie 4 speed then??
