Old 09-10-2004, 10:43 AM   #1
nroden
nroden's Avatar
Transmission Slipping
My truck doesn't seem to want to shift into 3rd, the RPMs go really high and then you have to keep on letting off and it'll finally go from 2nd to 3rd. Then after you get up to about 45 MPH it slips (more you press the gas the faster the engine goes but the truck isn't going any faster). I hope this is nothing major, but it may be time for a new transmission. Its a TH-350. How much do you think a rebuild would cost at AAMCO or someplace like that? The current one has approx. 109,000 mi on it.
Nick Rodenberg
72 Cheyenne 10 V8 350/TH350
white/ochre/white/ochre, ochre/saddle interior
Retired and in the dry... still runs. I now drive Red '01 Ford Focus... better MPG!!!
nroden is offline   Reply With Quote
Old 09-10-2004, 11:29 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Do this quick test. Go drive your truck around the block. Shift it manually. Start off in first, and go untill the engine should shift at light throttle, then wait for just a second or two longer, then pop it into second.
Do the same thing for third gear.
If it seems fine when you do this, then you need to inspect/replace the rubber ends on the vacume line for the tranny modulator. You can see a hard line on the back of the engine...on top of the intake on the passenger side. Look follow that to the carb and inspect the rubber hose, then same thing underneath. (It may just be poped off)
If all this is good, and the tranny is still reacting the same way, replace the modulator. (cheap/easy fix)
Old 09-10-2004, 03:31 PM   #3
old gm blues
Did you check the oil? My Th350 was leaking from the rear through the front tranfer case seal,so I never noticed any leakage, until I checked the oil lever from the transfer case and got a face full of dextron.
everyone is intitled to my opinion
1968 chevelle
1972 k-5 4x4
old gm blues is offline   Reply With Quote
Old 09-10-2004, 07:07 PM   #4
68 Stepside
huh?
68 Stepside's Avatar
If the truck doesn't wanna run over about 45 mph....but the engine still gains RPM's, the trans is definitely slipping. Providing the fluid level is correct, I would change the atf/trans filter, and hope that fixes the problem.
Let us know what you figure out.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 09-10-2004, 08:03 PM   #5
71Rat
ran out of money
71Rat's Avatar
when u change the fluid if it is burnt and brown/black it is bad. sometimes if it is that bad and u change it, the problem will be worse.... sounds like u need a rebuild...... i do them at our school and the rebuild kit is only like $50... but i dont know what a trans shop would charge.... i am assuming ur looking around $800.
Best of luck
Rat
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 09-10-2004, 11:32 PM   #6
Sweet72
Sweet72's Avatar
The no 2-3 upshift until you let off the accelerator is a vacuum related problem. As for the slipping, sounds like you have a internal problem, maybe as simple as a stuck valve in the valve body. Do what Longhorn Man said and take it for a run, then change the fluid and filter. Good luck
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 09-11-2004, 12:23 AM   #7
ZOOMY
trans
With these old trucks, sometimes the valve body is gummed up. I put in a pint of "Sea-Foam transmission additive", & drive it for about 100 miles before changing the fluid. Works sometimes; sometimes not.
ZOOMY is offline   Reply With Quote
