09-10-2004, 10:10 PM | #1 |
Removing auto shift lever
What is the easiest way to remove an auto shift lever? I have to replace the turn signal switch in the Blazer and that little pressed in pin is being stubborn. Or is there a way to replace the switch and associated wiring without removing the shift collar?
68 1 ton dually 292, 2001 Sebring, 2004 Trailblazer, 11 Camaro Convertible. |
09-10-2004, 10:41 PM | #2 |
its all about the +6 inches
shouldn't need to remove that. Just fish the harness through the shifter ring and down to the bottom.
