09-10-2004, 11:36 PM | #1 |
Need Help With Tires For New Rims
What size tire for the rear with 18x10 4.5 backspacing 4inch drop on a short fleet 1971 model. Front is 17x8 with 4inch backspacing 2.5 drop spindles. The rims are American torque thrust 11 I ordered the rear with this backspacing to keep the wheels under the truck. Thanks for any help.
71 cheyenne 402 th400 swb 71 camper special (PARTS TRUCK) 70 Stepside swb 350 Last edited by butter; 09-11-2004 at 07:23 AM. |
09-11-2004, 07:24 AM | #2 |
anybody
71 cheyenne 402 th400 swb 71 camper special (PARTS TRUCK) 70 Stepside swb 350 |
09-11-2004, 10:06 AM | #3 |
10's are fairly wide but BFG makes a 295-45-18 that would fit that size wheel & offer decent sidewall height. Pirelli also makes a 285-50-18 that would fit but w/that size your starting to get a pretty tall tire that will have effects on your overall gear ratio.
09-11-2004, 10:56 AM | #4 |
255X55X18 on mine. 29" in dia. works good with 3.73 gears.
10.4" wide.
72 CHEYENNE 10 SUPER 468/400/3.73 |
09-11-2004, 11:25 AM | #5 |
OLDROCK&ROLLER What brand tire are you running and do have any pictures? I am looking for about 29inch in height I also have 373 gears.
SCOTI Thanks for the information.
09-11-2004, 03:22 PM | #6 |
I'm running Yokohama's AVS ST.
09-11-2004, 09:15 PM | #7 |
Thanks for the picture you wouldn't happen to have one of rear would you?
09-11-2004, 09:37 PM | #8 |
Ebay Junky
oldrockandroller- what tires do you have on your truck?
1972 CHEVY C-10 SWB 2WD - Possible Typhoon 4.3 turbo drivetrain.. 1983 Chevy c10 swb 2wd - possible 350tbi supercharged... |
