Old 09-11-2004, 01:57 AM   #1
Bryce M
Can I just bolt in a 5 lug axle
I want to do a disc brake swap I plan on bolting in a 73+ crossmember My truck has trailing arms will a 73+ 5 lug just bolt in or am I going to need to get mounts made on it so I can stick it in
Bryce M is offline   Reply With Quote
Old 09-11-2004, 02:18 AM   #2
Sublvr72
Sublvr72's Avatar
71-72 axle shafts should swap out. I think the 73+ is longer by an inch or two on each side.
Sublvr72 is offline   Reply With Quote
Old 09-11-2004, 03:25 AM   #3
Bryce M
I planned On dropping in the Whole rear end since I can most likely get a good one for less then the cost of axles themselves
Old 09-11-2004, 07:31 AM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
It won't bolt in.
Your trailing arm rear has different mount saddles than the 73 and newer rears do. There were never any trailing arm rear trucks built after 72. You'll need to put the proper axle saddles on AND figure out some way to mount the panhard bar to the newer rear end. If you'll look at your trucks rear, you will see a big stud sticking out of the rear end that the panhard bolts onto. The 73 and newer rear don't have that.
Old 09-12-2004, 06:27 AM   #5
Bryce M
Thats what I figured So my options are buy a kit for 300 some odd dollars or get 73+ shafts and have them shortened or re drill my stock ones and use the later brakes
Or swap out the entire rearend
Old 09-13-2004, 04:11 PM   #6
flip66
flip66's Avatar
what year is the truck, what is your location I know a guy that has a set of 5 lug axles that where made to work with the 67-70 rearend and I think the is a guy on the board 67-72 board that has some 71-72 rear ends.
flip66 is offline   Reply With Quote
Old 09-14-2004, 04:08 PM   #7
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Bryce, What is your location?
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 09-14-2004, 04:38 PM   #8
Bryce M
I am in Canada in BC A ways off from most
Old 09-14-2004, 05:40 PM   #9
DennyB
DennyB's Avatar
Ah yea, I cant help ya with parts, sorry
I.M.O.M,W,J&C
Patriot Guard Rider
Old 09-14-2004, 06:56 PM   #10
grnddwn
belly dragger
grnddwn's Avatar
Probably be easiest just to get yours redrilled
grnddwn is offline   Reply With Quote
Old 09-23-2004, 05:27 AM   #11
longhorn71
longhorn71's Avatar
Smile
HI FROM ALBERTA
I have a set of 5-lug axles from a 72 pickup if you are intrested send me a PM we could maybe make a deal
longhorn71 is offline   Reply With Quote
Old 09-23-2004, 05:47 AM   #12
shadetree
shadetree's Avatar
Bryce, what year is your truck? 1970 rear axles are the same as 1971 and up. If your truck is a 1970, just swap axle shafts!
1970 long fleet, 355 4 speed, primer, walnut goodies
shadetree is offline   Reply With Quote
Old 09-23-2004, 03:09 PM   #13
grnddwn
belly dragger
grnddwn's Avatar
72 five lug axles are too long they are the same lenght as 73 to 87 axles
Old 10-02-2004, 08:04 PM   #14
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
70' was the year they started putting the longer axles in trucks. Some of the 70' trucks do have the shorter axles. I don't remember the length of either of these though.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 05-08-2005, 03:20 PM   #15
Billy G
Billy G's Avatar
ReKindlin' this post....
Can one measure the tube length between the drum....and the pumpkin??? Would that tell you if the longer axles will work or not???
I have a 70....dont know if it's the early or late 70 though.
Billy G
My FAMOUS LAST WORDS...."Ima Gonna!!"
- 1970 GMC 1500 swb/step 250 I-6 3 spd - "The GEM"
- 1976 Chev Scotsdale swb/step 350/350 - "The JEWEL"
- 1982 Chev C-10 swb/step 250 I-6 3 spd -
- 2001 Chev Silverado LT -
Billy G is offline   Reply With Quote
Old 05-08-2005, 04:01 PM   #16
el curioso
el curioso's Avatar
Im in the prosses of doing some thing like this look at the engine and drive train forum i posted a similar question that might help it's under this:
The Link
el curioso is offline   Reply With Quote
Old 05-08-2005, 08:10 PM   #17
neonlarry
neonlarry's Avatar
Here's a site with some axle width measurements: http://50chevy.freeservers.com/Suspension_Widths.html
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
