Old 09-11-2004, 08:35 AM   #1
ACP427
ACP427's Avatar
can I convert a non air cab????????
Hey guys, does anyone know how convert a non-air cab to vintage air? besides changing the dash, I am restoring a 68 and the cab is way too nice to wanna switch, but I do want the vintage air and have an old system to install, I noticed the holes on the firewall are different, how hard is it?? some one must have tried it !! any help would be apprieciated thanks Tony
ACP427 is offline   Reply With Quote
Old 09-11-2004, 09:57 AM   #2
mrein3
mrein3's Avatar
I think vintage air has a system where you don't have to modify any metal.
I had to modify my firewall to get a stock system to bolt up. The work isn't hard, it is just a lot of putzy work. I posted these once before...
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 09-11-2004, 10:24 AM   #3
mrein3
mrein3's Avatar
I just found this picture on the parts board. It too has been posted before. It is a good guide for anybody wanting to convert. I used it myself when I did the change. Note that the existing heater hose hole is the same on both which isn't perfectly depicted in the picture. I used the existing hole and the big hole on the right of the picture to line up my templates to make a paper then metal piece to weld in.
'72 Malibu hard top
Center City, MN
Old 09-11-2004, 01:50 PM   #4
ACP427
ACP427's Avatar
thats it?
Thats what I meant, a vintage or stock system, thats all ? just make the box line up, and it works okay? I was'nt sure if I had to do anything with the air vents on the kick wall or not? thanks for the info!!! Tony, Now as soon as get the hang of this mig welder I'll be alright, so far I can only make ****ty welds!!! But I am working on it!
Old 09-11-2004, 05:51 PM   #5
john
member #16
john's Avatar
Actually there is more. If you look at second pic straight up from heater hose holes there is a hole with a smaller one on each side to mount a vacuum controlled valve that works a flapper, and a valve on the pass kick panel vent. I dont know if they are needed or not. I think the cowl vent is for outside air. Good luck John
john is offline   Reply With Quote
Old 09-11-2004, 10:07 PM   #6
71swb4x4
71swb4x4's Avatar
I am sure you know this, but just in case you aren't sure I will throw it out. You must change all of the components inside and outside of the cab. The factory heat only boxes will not work with the factory AC system.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-11-2004, 10:25 PM   #7
Zeke
Active Member
I think you need to get a glove box for an AC cab to clear the inside AC boxes.
1969 C10 350 3spd
1995 GMC 3500 XC 350 dually
When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin
Zeke is offline   Reply With Quote
Old 09-12-2004, 02:57 AM   #8
tmcgrawlookalike
easiest would be to find an ac cab and put it on your truck.or,go get the vintage air system that is all self contained and fits under your dash.no cutting your virgin dash,making holes or anything.
tmcgrawlookalike is offline   Reply With Quote
