Old 09-11-2004, 02:43 PM   #1
Hotrodhenryj
Truck Farmer
Hotrodhenryj's Avatar
AC Problem
I posted this quesion on the newer truck board but it seems that it doesn't get the traffic this one gets. I know that there are some really good tech's here. So if you can help me solve this problem I would greatly appriciate it. Thanks, Chuck
http://67-72chevytrucks.com/vboard/s....php3?t=119285
My truck is a 95 and the AC quit. Fan still comes on, but no hot to the low pressure switch or the compressor. Checked all fuses, removed the dash and checked for hot to the switch. Push button switch is working corectly, has hot with key on. Fan switch has hot to it also and it has hots to all the fan speeds. I am not sure if this has a fusable link or some other type of fuse somewhere. Anyone know what could be the problem. Is there somewhere else I should be looking. Help me out here as I live in Arizona and its still 100+ out there. PLEASE!!!!!!
Arizona rust free sheetmetal
Hotrodhenryj is offline   Reply With Quote
Old 09-12-2004, 02:55 AM   #2
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Sorry. All the ac tech data I have is for 67-72 chevy trucks. Old tech stuff.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 09-12-2004, 03:02 AM   #3
tmcgrawlookalike
had the same problem with my 95 chevy dually-had to replace the heat/air control panel with a new one from gm-worked great after that,just like before.gm parts man said these were a problem on these trucks and they sell a ton of them.little over 100.00 bucks.good luck!
tmcgrawlookalike is offline   Reply With Quote
