Old 09-11-2004, 04:50 PM   #1
smbrouss70
smbrouss70's Avatar
C-10 vs. C-20 Front Susp. ??????
Are the front crossmembers on a 1/2 ton and 3/4 ton the same for 2wd in 1970?
I'm wanting to take a not running 3/4 ton and do the captkaos crossmember drop and then install it into my 1/2 ton daily driver. Will this work? Also, I need to be able to return the 3/4 ton to use hopefully with the 1/2 ton crosmember? I won't be swapping control arms or anything like that just crosmembers.
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 09-12-2004, 01:35 AM   #2
Sublvr72
Sublvr72's Avatar
yes, same crossmembers.
My burb was a C/20 when it came off the line, and now its a 1/2 ton. the 1/2 ton control arms bolt up to the same crossmember as a 3/4 ton control arm
Sublvr72 is offline   Reply With Quote
Old 09-12-2004, 08:52 PM   #3
BigChevMan
My Thoughts Exactly!
BigChevMan's Avatar
So on my 69 c-20 will the 73-87 1/2 ton arms and stuff bolt to my crossmember? What else would I have to do?
BigChevMan is offline   Reply With Quote
