Old 09-11-2004, 09:28 PM   #1
True Grit
Why Buy New?
True Grit's Avatar
Question cab rust repair,advice?
i'll need to replace both rockers and a portion of the floor pan,cab mounts and such. any advice? any repair pics? thanks in advance!!!
'71 GMC 1/2 Ton LWB
'71 Chevy 3/4 ton Longhorn
True Grit is offline   Reply With Quote
Old 09-11-2004, 10:28 PM   #2
rage'nrat638
rage'nrat638's Avatar
Thumbs up
you will be best off pulling the front fenders...
lay the new one's up there...make out with magic marker.. cut 1/4 inch smaller....clean...welder up....tack weld....
my tig welder has a pulse,, for doing such a thing....don't over heat....
seam seal....prime..paint...
rage'nrat638 is offline   Reply With Quote
Old 09-12-2004, 02:48 AM   #3
chevymaz
What are you looking at?
chevymaz's Avatar
welcome to the board fellow Okie
1971 GMC LWB
2005 Honda Element
2007 Honda Fit
chevymaz is offline   Reply With Quote
Old 09-14-2004, 10:54 AM   #4
raphyel
I built a cab stand with some scaffolding material. I weled it so that the cab supports sit on it. It lifts my cab about 2 feet off of the ground and is a lifesaver for working under the cab. as far as the welding. remove the rockers first. the inner rockers will probably have to be done also.cut the floor out and mark the patch with about an extra half inch all around. fine shpe the piece so you get a good weld and weld the floor. next do the inner rockers and then the outer rockers. I recently redid the floors in my cab.
raphyel is offline   Reply With Quote
