Auto OD column mod
Does anyone sells or has anyone have a how to guide to modify a stock three speed auto column to accept the four speed overdrive shift indicator and detent.I know that there are kits out there for the floor mounted shifters on cars but I have not seen one for the column shifted transmissions,is there such a kit out there?
its all about the +6 inches
If you mess with it for a while, you can fit it to where you can get all gears...park through first...all working with no mods. (from what I hear anyways) Then all you need to do is wax/polish the Park RND21 off the lens, and get your own stickers...or paint it on if you are more tallented...or don't care how bad it looks.
Seems many ppl just hook it up to where Drive is Overdrive, 2 is drive, 1 is second...and just live without putting it in first gear manually....really, when was the last time you NEEDED to put it in first and hold it? |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
What Longhorn said.
Mess with the linkage for a while and you'll get working. I even was able to adjust it so it still only starts in Park and Nuetral. I put my 700R4 in about 5 years ago now.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
#4 | |
When the snow is really deep I put it in 4-low AND select 1st on the column. A boat ramp with a long, steep incline. Road hunting for partridge. The snow plow guys use 1st alot too.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
![]() Join Date: Jul 2000
Ididit Co. sells an O.D. indicator that will fit the stock column with a little sanding. You can take the Xmsn . pan off and watch the shifter as it hits all gears and adjust the shifter rod accordingly should be able to get all gears and indicate properly on the indicator with minor tweaking. www.ididit.com
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar. 96 Impala SS 97 Monte Carlo |
