Old 09-12-2004, 09:21 AM   #1
our64
http://public.fotki.com/street
our64's Avatar
235 cu to a 230
Just wondering will a 235 from a 62 bolt up to my 1964 230. three speed, without changing motor mounts etc. Also would the 235 bolt up to a th350 automatic..Thanks in advance
our64 is offline   Reply With Quote
Old 09-12-2004, 01:30 PM   #2
Lgriffin
It's not a bolt in. There is a difference lenght of the two blocks, the 235 being shorter. There is also a difference in bell housings, between the 230 and 235.
Larry
68 C20 327/465 daily driver 4:56 och!
63 C20 292/420 Camper truck Detroit Locker 4:10 posi
65 C10 ? /powerglide Custom Cab AC,PB,PS,4xflasher
70 C10 250/3spd org/Gauge dash,Wood bed, 4Sale$1300
Lgriffin is offline   Reply With Quote
Old 09-13-2004, 01:21 PM   #3
60-66 Nut
Professional Beer Tester
Like Larry said,it's definatley not a bolt in.The 235 shares very little with the 194,230,250 and 292 engines.The 235 has the mount in the front rather than on the sides,and the bellhousing is totally different.The only automatic I know of to fit the 235 without adapting is the old castiron powerglide.
60 Ford F100 Custom Cab
61 Apache Short Fleetside
64 C10 Short Stepside
65 C80 409 V8 5spd(X-Firetruck)
83 GMC 350 Olds Diesel
85 GMC Short Bed
86 GMC Short Bed
90 GMC R3500 Crew Cab
92 GMC 1500
60-66 Nut is offline   Reply With Quote
Old 09-13-2004, 08:26 PM   #4
our64
our64's Avatar
As always, Great Advice..Thanks guys
Old 09-13-2004, 10:44 PM   #5
Lgriffin
Our64, What you want is a good running 292, with the passenger side motor mount bracket. and some say the alternator bracket. Then everything interchanges except maybe the flywheel or starter. You can have your flywheel drilled to fit the later crankshafts.
Larry
