Old 09-12-2004, 03:58 PM   #1
legends
Dropped spindles with bags ?
How much drop can i expect in the front using bags only? Do most run drop spindles with the bags?
legends is offline   Reply With Quote
Old 09-12-2004, 04:12 PM   #2
ghetocrewzer
ghetocrewzer's Avatar
You need spindles in the front to keep the alignment a little closer and to get that extra 2-3 inches of drop.
ghetocrewzer is offline   Reply With Quote
Old 09-12-2004, 04:21 PM   #3
NO LONGER DISTURBED KONCEPTZ
NO LONGER DISTURBED KONCEPTZ's Avatar
You can get a lot of drop with just the bags but like ghetocrewzer said the spindles help you with the alignment and If you want the truck to lay out you will need the spindles.
NO LONGER DISTURBED KONCEPTZ is offline   Reply With Quote
Old 09-13-2004, 10:28 PM   #4
PrimeredThunder
Back from the Dead
PrimeredThunder's Avatar
I've got bags and no drop spindles...its gets it pretty low, but there is still some pretty crazy camber issues when you drive low. If you can afford it, get the spindles and get'r down on the ground!
Kenny
The only Carb that matters to me is the one under my hood!
Salem, Oregon
PrimeredThunder is offline   Reply With Quote
Old 09-14-2004, 04:35 AM   #5
ACES
Life is a gamble
ACES's Avatar
If you are putting the bags on a 67-71, I would recommend the drop spindles not only for camber issues as discussed above, but also to upgrade to disk brakes.
1970 Orange CST C-10 w/350, posi, Longbed
The torpid artist seeks inspiration at any cost, by virtue or by vice, by friend or by fiend, by prayer or by wine.
-- Ralph Waldo Emerson
ACES is offline   Reply With Quote
Old 09-14-2004, 11:31 AM   #6
Sublvr72
Sublvr72's Avatar
Aces, are 72's not included?!?!
btw, I am running spindles and bags and the camber does not get too out of control
Sublvr72 is offline   Reply With Quote
Old 09-14-2004, 01:36 PM   #7
legends
Thanks for the input, i have discs on my 71 now, but i think i will go with the lowered spindles anyways to keep the camber under control.
Old 09-14-2004, 01:40 PM   #8
XXL
Seņor Member
XXL's Avatar
71-72 came with disc brakes... so assuming the extra benefit is only on 67-70.
XXL is offline   Reply With Quote
