Old 09-12-2004, 07:27 PM   #1
botboy
How big alternator (84 K5 Diesel)
I'm curious how big the alternator is on my '84 K5, 6.2 diesel, 700r4, it appears stock or stock replacement, PO didn't say it had ever been replaced so it may very well be factory.
I'm curious because my '72 had a factory 63 amp externally regulated POS and it sucked, fixed several problems when I replaced it with a 105 amp model from a '93 burb (swapped pulleys), and this K5 usually gets the inverter I use to run my laptop to start screeching about low voltage if it sits at idle for too long, and I would like to change that. I also think that with dual batteries (and I'm considering adding a third for glow-plugs only during the winter) I should probably have a better charging system for the cold weather.
botboy is offline   Reply With Quote
Old 09-12-2004, 08:18 PM   #2
RockHQ
ROCKET POWER!
RockHQ's Avatar
63 amps if the fan has separate blades, 78 amps if the fan is a disc type fan, both are SI series alternators. Now this may be strange but your truck could've come with either from the factory, regardless of the dual battery option.
Btw your thinking is skewed in that glow plugs do not place an especially heavy load on the battery. It's the starter motor.
Because of the long cold winter over here, diesel engines are a big income source for shops and that's why i've had to deal with these engines in cold weather a lot more than i care for.
The battery leads GM uses in our trucks are a big problem. The passenger side battery's positive cable ends flatten out after being opened/tightened a few times. The rubber insulation covering the outside diameter of the cable ends hardens up. The cable ends are a sandwitch design with several different metals all connected as an electrochemical pair which causes severe oxidation.
The cable ends are too thin and too deep inside the insulating rubber.
Combine all of that and you get what i've had to witness, and deal with both in my own vehicles as well as customers, the passenger side battery positive terminal gets hot enough to melt the cable insulation during cold starting of a 6.2/6.5 diesel engine. The 6.2/6.5 liter engine is really, really difficult to turn at temperatures way below freezing point. Not only that but it needs to be spun at a steady 300 or so rpm before it will stay running. The moment when the starter solenoid plunger engages the main current bridge but the anchor isn't actually turning yet is more or less a direct short where amp draw can be in excess of 600 amps easily.
Adding a third battery is a-ok but do it in a way to get more juice to the starter!
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
