Dash ?
The dash in my blazer has been cut for an aftermarket radio. A friend of mine just gave me a parts pick-up with a uncut dash. How hard is it to change out? Thanks Ed
Not bad if you have a welder. Remove the 3 bolts on each side-remove dash pad-cut dash along where holes are-cut new dash in the same place-bolt back in and just tack weld the dash down the line of holes-does not have to be perfect as it will be no see.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
At the sides where it bolts in it might be spot welded there, some are some aren't. It took me a couple hours to get the spot welds undone on mine, you can't get a drill in there, I ended up pealing the metal apart to get the old dash out.
