Old 09-13-2004, 01:44 AM   #1
darksaga
darksaga's Avatar
valve cover issue
I recently droped a built 454 engine into my 68 k2500 and the edelbrock elite valve covers are posing a clearance issue
I have 1.8 ratio harland sharp rocker arms and I need shortet tall valve covers that will clear these
the covers are right against the firewall and the booster is really close
any one know of any covers that will fit?
the truck also originaly had a v-6 as well
1968 gmc 3/4 4x4 longbed. built 469 700r4 (needs a th400 REAL SOON!), 14bolt ff rear 73 3/4 dana 44
1970 chevelle all wheel disc, tubular rear control arms tall spindle swap up front matching #'s 350 work in Progress
darksaga is offline   Reply With Quote
Old 09-13-2004, 01:59 AM   #2
67cst
i love summertime
67cst's Avatar
this might be a dumb question but can you put a big block in the 6 cyl position like you can with a small block? maybe thats the problem, its sitting too far back, or maybe im just an idiot lol
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 09-13-2004, 02:04 AM   #3
darksaga
darksaga's Avatar
oh it had a 402 a few months back, so it should fit the option of pulling everything forward 1/4" does exist but if i can leave everything as is I would be much happier (the exhaust will be fine ect)
I thought about taking a hammer to the firewall but i don't want to go there, would rather do it right
I know some one else has to be out there with a bbc and roller rockers
Old 09-13-2004, 07:18 AM   #4
cdowns
cdowns's Avatar
i vote for the hammer
Old 09-13-2004, 08:39 AM   #5
Fred T
Cantankerous Geezer
Fred T's Avatar
Time for the BFH!
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 09-13-2004, 09:00 AM   #6
crazy longhorn
Fabricate till you "puke"
Ill 3rd that hammer on the booster, you can go aftermarket & get a smaller dia unit. best of luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-13-2004, 11:23 AM   #7
nate68
it's hard to tell which booster you have. the 1/2 ton had a larger diameter than the 3/4 ton ones (i think)
68 short step, 406/700r4, 9" w/discs.
nate68 is offline   Reply With Quote
Old 09-13-2004, 12:56 PM   #8
FormerMember
I have the same problem. Went with a short Billet Specialties set from Summit Racing.
Cleared my 1.8 roller rockers (barely)
FormerMember is offline   Reply With Quote
Old 09-13-2004, 01:18 PM   #9
OregonLonghorn
go back to the 402! better motor! LOL
OregonLonghorn is offline   Reply With Quote
Old 09-13-2004, 01:59 PM   #10
70short
Someone else had the firewall issue I think. I believe he is building A silver flatbed. "YUKON JACK"????????????
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 09-13-2004, 02:14 PM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
A body lift...or more of a body lift would solve this problem.
Old 09-13-2004, 02:23 PM   #12
FormerMember
I thought about that. Decided that it would look seriously goofy on a 2wd truck.
I am still thinking about a drop for mine, but don't want to lose tow/haul capacity.
Old 09-14-2004, 12:20 AM   #13
darksaga
darksaga's Avatar
can't it looks like this now
Old 09-14-2004, 12:26 AM   #14
darksaga
darksaga's Avatar
I am really thinking about using ORD's 1" aluminum spacers that would solve the boster and passenger side issue but the drivers side firewall would still be a prob, it would only need ~ 1/8" or so to clearance to get the needed room
http://www.offroaddesign.com/catalog/oneinchlift.htm
I could just buy the pucs
Old 09-14-2004, 01:05 AM   #15
69 Short Fleet
I went through this problem with my smallblock, I first installed PT # 4249 *(B) Tall ones and I had firewall clearance problems so returned them for PT # 4248 (B) Low ones and no problems. However I just checked Edelbrocks website and they don't make the low ones for a BB only yours (PT # 4280 Tall) wonder why?
69 Short Fleet is offline   Reply With Quote
Old 09-14-2004, 09:52 PM   #16
darksaga
darksaga's Avatar
well I put the chrome (ick) valvecovers that where on the prev eng and they bolted down fine, I still need to turn it over and feel to see if the rockers are hitting I may try the billit specialty ones
does anyone have any exp with the alumnum spacers for VC?
also I think it would be fine if the top of the vc was curved not a right angle
