Old 09-13-2004, 05:41 PM   #1
cliffsta
Stepsides RULE
cliffsta's Avatar
Washer pump..Help!
Okay. I think my washer pump is clogged, but I'm not sure. I checked all the hoses (from water jug, and both to outlets) and no clog; the outlets don't squirt water. I'm not sure if the pump is sucking water from the jug. Do you think the pump is junked way up, causing not enough pressure to suck water? Or could the pump just be tired? What do y'all think? Maybe it's getting water, and i can't tell, meaning something else is clogged.
Also, I'm not sure how it all disconnects so i could remove it from the truck. I see like 2 or 3 bolts on the firewall, but it seems kinda tangled into all the electrical system. Any help is such greatly appreciated (or whatever)
cliff
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 09-13-2004, 05:46 PM   #2
Prerunner1982
Prerunner1982's Avatar
could just be tired.. mine stopped pumping and i went with an aftermarket unit.. it small but rather loud.. i just tied it into the stock wires and mounted it off to the side of the original pump..
Prerunner1982 is offline   Reply With Quote
Old 09-13-2004, 08:21 PM   #3
cliffsta
Stepsides RULE
cliffsta's Avatar
Yeah it ticks and sounds (and spins) like its trying to pump, but nothing much is happening. Definately going a bit slow for what i think it should be doing. Maybe a universal pump should be on my Xmas list, since mosquitos and such are bad enough to warrant the washer pump. That or a lot of windex ing.
Old 09-13-2004, 09:06 PM   #4
88Jimmy4x4
88Jimmy4x4's Avatar
Im sure its just the pump, they cost about $20 or so from your local autoparts store. Mine 85 is located at the fill jug on the drivers fender, kinda fits in a groove of the jug. I changed mine and it only took about 10min, but you do have to remove the fill jug.
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 09-14-2004, 12:26 AM   #5
cliffsta
Stepsides RULE
cliffsta's Avatar
ahh, on my 80, the jug is seperate from the pump, the water gets to the pump through a bigger hose than the 2 outlet hoses. But its the same principle im sure. TY all for your help.
Old 09-14-2004, 01:12 AM   #6
76HighSierra
DAMN, I love Big Blocks!
76HighSierra's Avatar
If you're sure the pump cam (on the wiper motor) is actuating everything, then it may possibly be the diaprams in your pump. They can be gotten at your local "vato"zone. :p Mine is doing the same thing, but since it rains so rarely here, I haven't been motivated to do anything about it.
Marc Bona
Hobbs, New Mexico
1976 1/2 ton GMC High Sierra.
454 c.i.d./ TH400. *Soon to get a mild warming over.*
3.40 rear.
76HighSierra is offline   Reply With Quote
Old 09-15-2004, 04:48 AM   #7
the baron
the baron's Avatar
Before dismantling whatever , just check your sprayers ( with a tiny wire ) , they might be clogged either...
1982 Suburban 2WD , 260ci Olds engine,TH400 , will get a 1979 front clip , might be ready in ... 2016
1985 Chevy Van ( 305/350 ) , "Kellogg" equipped , my actual D.D.
1960 Girl Friend , frame still good , body has some dents
the baron is offline   Reply With Quote
Old 09-15-2004, 05:52 PM   #8
cliffsta
Stepsides RULE
cliffsta's Avatar
no, water isn't even getting to the pump i'm pretty positive, i think its just tired. NO biggie, there's always Windex and paper towels
Old 09-16-2004, 01:50 AM   #9
badone07
Project 2 Resume
badone07's Avatar
Had the samething happen to mine. Actually never worked since I bought it. Like 76HighSierra said, mostly it's the diaphrams in the pump. Mine hasn't worked in the last 7 years until last weekend. Figured since I installed a delay wiper setup, might as well fix the pump. Put a simple repair kit in it. Took a couple of minutes and cost around $8.
badone07 is offline   Reply With Quote
Old 09-16-2004, 11:49 AM   #10
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
Badone,- Interested in your wiper delay set up. I saw a stock looking set up in a Carcraft? magazine that used the factory switch location. The company was geared towards old Firechickens and Chevelles. Sure it would work but it was over 2 bills.
Cliffsta,- If you take out the instrument panel you can get to the washer/pump a lot easier. The kit (wich I am having troubles locating localy) is pretty easy to install. Just a few rubber seals and valves. I ended up lubing mine with lanolin hand cleaner and everything works now.
Rich
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
