Old 09-13-2004, 11:05 PM   #1
shortymac83
hmm...
shortymac83's Avatar
questions
what pieces from a 1968 model will fit on my 67? I spotted a white (with black spraypainted stripes like a zebra) 68 C10 in the yarde with perfect inner fenders, hood and doors, and rust-free grille and headlamp moldings. Will this stuff change over?
I've got the 250 with a 3 speed manual, and I've been told that it's got at least 3.73's in the rearend. I'd like to go with much taller gears (3.08 or 3.23) because I'm not going to be using this truck for work, rather more for driving and/or showing. This means that it needs to go 75-80 mph on the highway comfortably since nearly everywhere that I would go is on interstates with 65+ MPH speed limits. is there a JY source for these gears? if not, what company do you reccomend? It's not going to see snow, and it's going to be low power, so I'm not worried about limited slip.
Which brings me to my next question. Exactly what transmission do I have, does anyone sell a rebuild kit for it, where can I get a rebuild kit for the linkage (bushings are wearing out), and what is the clutch that you would reccomend?
Lastly, as I mentioned before, this truck isn't going to see work, so I don't care if the wood in the bed is a "soft" wood like pine, instead of the traditional oak. What do you guys think is the best wood to use in regard to overall looks? I really like the look of perfect, varnished oak, but a well-stained pine can look cool too. I'm also kinda partial to maple. Regardless, teh truck will be a very dark blue metallic, if that makes a difference. I'm leaning toward maple at this point.
1983 Oldsmobile Delta 88
1967 Chevy C-10 stripper
www.fcrperformance.com - wanna go...faster? talk to FCR.
shortymac83 is offline   Reply With Quote
Old 09-14-2004, 08:12 AM   #2
shortymac83
hmm...
Ttt
Old 09-14-2004, 08:22 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
All of the body parts interchange. 68 has marker lights, 67's don't.
Try looking in factory V8 trucks for a 3.08 rearend.
Old 09-14-2004, 12:05 PM   #4
shortymac83
hmm...
cool. Will any year rearend work? Thanks in advance.
Old 09-14-2004, 01:34 PM   #5
JimKshortstep4x4
Smile
67-72 truck 12 bolts will be a direct bolt in. Other year trucks may have bracket problems.
Jim
Old 09-14-2004, 01:36 PM   #6
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Factory wood was southern yellow pine.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
