Old 09-14-2004, 12:15 AM   #1
BaggedC10
Under construction!
BaggedC10's Avatar
Question PST or GM motor mounts?
Everything on my truck is polygraphite except the 4-link/panhard bar. How would PST units compare to GM mounts? More vibration or what? Thanks for any advice.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 09-14-2004, 01:32 AM   #2
TIMSPEED
TIMSPEED's Avatar
I dunno about GM ones..put I have a set of Energy Suspension Polyurethane motor mounts.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 09-14-2004, 03:01 AM   #3
BaggedC10
Under construction!
BaggedC10's Avatar
Did you notice a difference between the original and polyurethane units, Tim?
Old 09-14-2004, 08:56 AM   #4
bluex
bluex's Avatar
I have energy suspension poly engine and tranny mounts on my S10. When the a/c is on, or its idling in gear it is trying to shake itself to death. I will never have another set of poly engine mounts. I can only imagine how bad it would be if you had a good sized cam. Its really annoying, I want to change it back to rubber, but dont have the time or $$ as I have about $150 in these. They required custom made frame pads.
bluex is offline   Reply With Quote
Old 09-14-2004, 09:16 AM   #5
swervin ervin
You get what you pay for
swervin ervin's Avatar
I have Energy Suspension engine and tranny mounts in my 85. All I noticed was more vibration. When at idle you can feel the engine running but it doesn't shake itself to death by no means and I have a Comp XE268 cam.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 09-14-2004, 10:15 AM   #6
ocbaud
Garage Queen Material
i have energy suspension engine mounts and the stock rubber tranny mount(for now). it does rock back and forth a little bit(tiny tiny bit). but i like it
ocbaud is offline   Reply With Quote
Old 09-14-2004, 10:16 AM   #7
TIMSPEED
TIMSPEED's Avatar
I was always told, that if you run poly engine mounts, you MUST run a rubber tranny mount, or else SOMEWHERE SOMETHING will crack/break. I have more vibration than rubber, I'll say that..but it's not bad.
See Them Here
Old 09-14-2004, 09:04 PM   #8
SanitysBane
y not run solid motor mounts?
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 09-14-2004, 09:22 PM   #9
plumbcut
california fill
I run energy suspension polyurethane motor/spring/trans/body/swaybar etc etc and yes you will notice more vibration! Would I do urethane motor mounts again? probably.
If youre looking for ultra comfort in your vehicle, Id go rubber. just my 2 cents
pc
plumbcut is offline   Reply With Quote
Old 09-14-2004, 09:31 PM   #10
BaggedC10
Under construction!
BaggedC10's Avatar
Thanks for the input, everyone. Looks like I'll be purchasing PST motor mounts soon.
Old 09-15-2004, 12:34 AM   #11
ocbaud
to stiff for a truck that you would drive a lot(for most people anyways)
