[Pics]More pics of the 5" Front Drop
Here ya guys go. Interesting...my Crossmember is STILL exactly 5.75" off the ground!
Garage Queen Material
4" drop
#3 | |
allright i have no clue at all how much the truck is lowerd but i have 3 inches from the top of a Dr. Pepper can. anyone have a clue how much drop that would be, and both of y'alls trucks look great, wished mine looked that good, great job the both of ya
'96 Nissan Pathfinder '02 Firebird Trans Am. '88 K5 Blazer |
Under construction!
Low84's truck looks lower up front, Tim.
2001 Silverado bagged on 22's. *Sold* |
Looking @ 67 Chevy Short Step
what did you use to get that drop, where you get it and how much it cost you? thanks
You get what you pay for
![]() Join Date: Dec 1999
Tim,
what size are your tires? I have 27" tires (255/50R17), 2.5" spindles and 1.5" coils. I have exactly 5.75" at the crossmember also. Besides the fact of this measurement, your truck looks more like 4" in front instead of 5. IMO, there is no way your truck is riding at 5" in the front. I wanted to be pretty precise on my drop. This is why I chose to go with a name brand maker of my components. You get what you pay for is what I always say.
Mike 1985 Chevy C-10 |
i've got western chassis 2.5" spindles and western chassis 1.5" coils, with 28" tall tires (275/60/15's)
tim has 255/55/17's (about 28" tall) ![]() i guess i should note also, my truck was a tad bit lower in the front with the old engine. Last edited by ocbaud; 09-15-2004 at 12:29 AM. |
#9 | |
Under construction!
While I agree 100%, Ground Force is a quality name. Either way, something isn't right here. ![]()
#10 | |
#11 | |
Under construction!
If your happy, that's all that matters. ![]() Are you going to C-notch the frame and add 2" shackles? ![]()
#12 | |
#13 | |
Under construction!
Nice! A C-notch and helper bags' would be cool. ![]()
#14 | |
Yeah that sway bar and the power steering wieghs alot ![]() You didnt remove this in the sake of shaving wieght did you? |
#15 |
Maybe its just me (I just got home from a 12 hr. shift), but your right spring looks like its not in the upper pocket at all in the two pics of the front??
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
#16 |
my front tires just barely tuck with my 5 inch drop. thats 27 inch tires. and i don't think i could fit a standing coke can under my crossmember at all. lca's only have 3 inches of clearence.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
#17 |
The springs are installed correctly, as best as I can get them.
No, I didn't REMOVE the swaybar, my truck never came with one, and I have power steering, I meant like no AC, power brakes/windows/doors. Maybe the springs need to "settle"? |
#18 | |
You mean to tell me you drive around without windows and doors? ![]() That stuff wont make the truck wiegh no more or less than 100 pounds. The ac power brakes etc. |
#19 | |
#20 |
My 1980 Blazer 2wd is down 5.5 in front and looks like Timspeed's. 3" DJM Spindles and 2.5 drop springs. My LCA's are real low but have not hit yet.
Doug |
#21 |
how did ya'll get the can under the front end ican't do that
#22 | |
Hotwheels?
1978 Money Pit - CUSTOM DELUXE!!!! |
#23 | |
Western Chassis 2.5" coils and 2.5" spindles and 255/60/15" tires |
#24 |
yeap eric is right. 5/7 western chasis drop with 255/60/15 bfg's all the way around. its about to be changed up quite a bit though
#25 |
Hotwheels?
Nice. thats the tire im running. I want it that low in the front. Ill MAKE SURE it gets that low. I have 2" springs right now and adding some DJM spindles that im gonna have to order for the second time now
