PS Pump pictures?
Anyone have a picture of the BBC power steering pump that has the remote resevoir on it. I need one for my 454 and am considering altering a standard pump. I know how costly the factory ones are!
72 Chevy A/C P/B P/S Tilt 454 Engine 400 TCI Trans C30 Frame C10 Suspension Short Wheel Base (Dually) |
pic
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
Watch out for your cornhole !
![]() Join Date: Jun 2003
-factory GM sticker still intact on the bracket in that picture Rod posted-
Tx Firefighter shakes his head in amazement..... |
Rod, Do you have a picture that I would be able to better see where and how the nipple for the hose is attached? Thanks
you can get a bracket from, I think its called, allen grove pullies for 60.00 to add just about any pump. I used one works great.
Thats the Hillbilly way
I sent some Pic of the PS setup to 1970 CST Short Wide awhile ago ,I deleteted them from my pic though , he may still have them .I can take some new ones later today .
Do you need anything else besides where the hoses attach. ?
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
#7 | |
Resident Curmudgeon
![]() Join Date: Dec 1999
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Bill72BB, I'm really interested in a close shot of where the hose connects and would also like to see where the remote resevoir is mounted.
I can get you whatever pctures you need off of my truck when I get off work in the morning.
The reservoir mounts on the left fender, right behind the little triangle core support to fender brace. There is a great diagram in the factory manual showing exactly where and how to drill the reservoir mounting holes on the fender. There are two different locations for the reservoir, depending on whether your truck has one or two batteries under the hood. I used the manual diagram to drill the holes on my truck when I converted from manual steering 6 cylinder to power steering big block.
#10 | |
![]() Join Date: Nov 2001
Mine was leaking there and I was able to solder it with a propane torch and 50/50. I replaced the pump but when you do you only get the pump, not the housing. It is also press fitted on though easy to change. I could have ordered one with housing but the availability was unknown. I would bet you could just get a brass heater hose outlet and solder it on. for the hose connection to the remote tank. Well now that I think about it, maybe not if you are using a small block pump. Not sure if the housing come off of them like the BB. Rick H...
Rick H.... 69 C10-CST Wood bed floor full power 70 SWB 425hp HOTROD! Full power 71 C20 Camper Special 402 full power, factory dual tanks with gauge switch. FOR SALE! |
Here is what I just took
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , Last edited by Bill72BB; 09-15-2004 at 09:22 PM. |
another from 69burb i believe he posted it at one time.
#13 |
Wes posted this one time.. its a 68 with an arm off the fender to put the resevoir outward some... Ive seen this set up too.. so its correct also.
#14 |
Thanks everyone! This is exactly what I was hoping for. Now to get busy.
