Old 09-14-2004, 11:33 PM   #1
alpha_male0203
95 extended cab sportside
alpha_male0203's Avatar
cluster lights help please
mine are not working and i dont have a clue what to lok at first what is can be my turn signal works when i have the brights on thiose lil two lights work and all the gauges work jsut fine there is nothing worng with them. whatr do i look at thanks shane.
95 Chevy k 1500
00 Chevy Silverado 1500
07 cobalt Old ladies car]
alpha_male0203 is offline   Reply With Quote
Old 09-15-2004, 04:25 PM   #2
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Double check for taillights to make sure the tailights/cluster fuse is not open. Other than that, check the light/dimmer switch. It is also possible that all the bulbs are burnt out. But not likely.
NeCrOmAnCeR is offline   Reply With Quote
Old 09-15-2004, 08:04 PM   #3
alpha_male0203
ok anyone got a switch to spare around? cheep or donation
95 Chevy k 1500
Old 09-16-2004, 12:01 PM   #4
chickenwing
Lovin' Life in Miss.!
chickenwing's Avatar
check cluster ground. If I remember right it is just a clip that snaps on the dash sheetmetal.
The truck... you hear that? No really, you did hear that?!!!
chickenwing is offline   Reply With Quote
Old 09-16-2004, 03:49 PM   #5
alpha_male0203
is it the cord that goes from the right side of the cluster to the cig metal? that is loos but if made it tight and still dont work i check all the conections and everything and nothing.
95 Chevy k 1500
Old 09-16-2004, 04:18 PM   #6
hotrodhomi
hotrodhomi's Avatar
have they ever worked for you? the dimmer switch might be turned all the way down...not that anybody would do that..cough girlfriend cough. I would check for power at the switch first.
hotrodhomi is offline   Reply With Quote
Old 09-16-2004, 04:45 PM   #7
alpha_male0203
yea they worked and all the turned up. check power though. i get power to head lights and then the brights those blue dots and then the two turn singals and that is all and then gauges all work. don't have a clue what it is unless the whole switch is bad and only working part way.
95 Chevy k 1500
Old 09-16-2004, 05:14 PM   #8
mckpaul
mckpaul's Avatar
The cord that goes from the right side of the cluster to the ash tray metal is a small fiber optic. That whole connector where it connects to the dash comes out and has one of the dash bulbs in it. The fiber just carries a little bit of light down to the ash tray.
(Gotta give credit to TROYLV here on the board for that one for explaining what that was to me when I asked a while back)
Paul
1984 Chevy C-10
*LWB/305*
mckpaul is offline   Reply With Quote
Old 09-16-2004, 10:40 PM   #9
alpha_male0203
ok i replaced the switch nothing differet i can turn it and i get light to the dome but noithign esle but what i said about the blue brights and the turn singal i dont know. and its making me made
95 Chevy k 1500
