I am assembling a workshop and am interested in knowing what tools you find useful for repairing/restoring your truck, and those you're disappointed in. What comprises a minimal shop. How about a dream shop?
Links to a buying sources would be great if you have them. Thanks! ![]() |
Resident Curmudgeon
![]() Join Date: Dec 1999
Compressor, mig welder, torch, and sawz-all
![]() To me a torch is a necessity. You can't wrench 35 year old rusted bolts
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Still drivin' a Rat Rod
CPNE said what I was gonna say,don't forget an air ratchet,and impact,a good set of wrenches,and sockets.And a good strong garage jack,and jackstands.Nothing worse than trying to work under something and it barely being chest high.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
1969 Custom 30 wrecker
Add a sandblast cabinet to that list. I built my own. The quality of your work will go way up with one of these.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
user # 2756
![]() Join Date: Jun 2001
or a parts cleaner. Also, specialty tools- pullers(steering/balancer etc...) a press would be nice.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
buy two sets of wrenches. you will run into alot of bolts that has the same size nuts backing them.
72 long fleet (WIP) ![]() 00 Astro every day ![]() |
#7 | |
Left Foot Functioning
![]() 10,000 Pound Asymmetric Lift / Wide If you're building a shop, you might want to at least beef up the concrete pad where you would want to put one of these. I've been watching them become more widely available for the past few years. SSOW ![]()
69 C10 (#1 son's ride) 72 C20 (Dad's farm truck) 82 K30 (Ex - brush pumper project) |
Watch out for your cornhole !
![]() Join Date: Jun 2003
I have big stuff of.....
jack and stands MIG welder torch blast cabinet parts cleaner engine stand engine hoist Caterpillar diesel front end loader for lifting heavy stuff tons of electric tools like grinders, sawz-all, etc....
bob...how did you make your sandblast cabinet???
TIP makes a great build it yourself kit for blast cabinets.
i've got to the age that it seems like the 2most important tools in my workshop are the air conditioning system and the refrigerator
huh ???
Don't forget a BFH for when your friends bring their ford by to work on it...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
#13 | |
#14 | |
#15 |
![]() Join Date: Mar 2004
let's see so far i have found these items usefull
grinder air chisle -great for poping ball joints apart and getting ribbits out impact 2 3/8's rachets one with a swivel head 2 sets of open/closed standard wrenches 2 sets of 3/8's standard sockets one short one long ----get 6 sided there stronger extentions 1in 2in 6in + a really long one for reaching odd areas 1/2 to 3/8's adapter - i have found it faster to use this than changing air tools small hammer big hammer 5lbs pliers needle nose pliers wirecutters dentist pick 1/2in sockets 5/8's-1 1/8th 4 jack stands floor jack ziplock baggies permnate marker to mark whats in the bags torch or something to get bolts hot so they come out penetrating oil a bottle of fast orange - abrasive hand cleaner a small hand held sandblaster and a face sheild a computer with a helpfull posting board such as this one engine stand-usefull if your going to build one otherwise don't bother an overhead hoist for lifting engines in and out and lifting off major body parts fabric tow straps for lifting those body parts off -use 2 or 3 set of screwdrivers drill drill bits - save time buy the good ones.....a good set will cost around $200 or about $12-20 a bit a soft plyable air hose - you may have to make one but it's nice to not have to fight it. air compressor ajustable wrenches razor blades air cut off tool -also called a whizzer sawzall and plenty of blades power washer optional but great for cleaning parts body tools: hopefully someone can fill this in i haven't gotten there yet hope this helps, ondrew |
#16 |
Thread chaser set, oil seal driver kit, a decent digital multimeter (Fluke are highend unitis and worth it! IMO) that can give you dwell angle measurements, a decent set of taps & dies.
#17 |
Lovin' Life in Miss.!
lots of lights, lots of 20amp plugs, at least 1 220 outlet,drill press, floor model if you have room bench model otherwise. Bench grinder at least 3/4 horse, equiped with various stones, wire wheels and buff pads. Creeper. Good resperator if you paint/sand blast. Eye protection. At least a 6" vise. Shelving, shelving, shelving. Epoxy coated floor (my GOD it's nice!). Beer fridge, tunes and band-aids. I also have a dedicated shop garbage can. It's nice to rummage around in just dirt for a part/box/label/instruction you screwed up and threw away by mistake.
The truck... you hear that? No really, you did hear that?!!! |
#18 |
Don't buy too small of a MIG like I did. Harbor Frieght has good prices on Ingersoll-rand air tools. thetoolwarehouse.net has good prices on OTC and other brands. My brother runs a Huskey air compressor at his shop, runs it pretty hard and it works well.
'70 K-20 San Diego, CA |
#19 |
I bought a small mig,cause well money is the dictator,but I have a nice arc welder for the big jobs
![]() Also just picked up a tire changer,and stereo with a CD player is a must. And A nice big broad broom.
#20 |
Shop
NAMASTE B&E 1971 LONGHORN C-30 1969 LONGHORN C-20 1968 DUALLY 1970 STEP SIDE PROJECT 1972 CST C-20 1980 M-80 MALIBU FOR SALE 1974 NOVA FOR SALE: ![]() ![]() |
#21 |
Old Skool Club
All good ideas, previously expressed. But, here's what I'd like to see added to the list to make a "Dream Garage"
Cordless Telephone Television, with cable/satellite and a remote I have a brake bleeder, a cooling system pressure tester and I'm looking for a good deal on a Porta-Power. Howzabout a Block and Tackle, or other hoist system? A nice, big FAN!! It gets hot, sometimes, down south. Automatic hose reel Automatic Cord reel Multiple air drops along the walls, with water separator and a lubricator, in-line. Also, putting a Quick-connect on the outside wall of the garage/shop, could be handy. Oh, maybe a pit, if you can't put in a lift. But a nice 10K lb two or four post lift would be sweet.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
#22 |
Merciless Butcher
My favorite or most used tools:
For hand and air tools, I have nothing but Mac or Snap On Lincoln Pro Mig with large bottle ( just traded old one in for larger one) Lincoln Plasma Cutter Portable spot welder Set of stubby Mac wrenches Set of Intermediate Snap On wrenches Set of Standard length Mac Wrenches Set of Extra Long Mac Wrenches sizes 3/8" thru 1-1/2" Fitz-a-dent stud welder and puller for dents Mac cutoff tool with flexible head Mac 1/2" drive impact wrench ( given to me by junkyardjohn and it's a ripper) Snap On tap and die set I have a thing for tools. I have two pretty good size Snap On rollaways that are packed and getting heavier all the time. When I make the move to Vegas, I feel sorry for the guys that have to move all the stuff in the garage.
Your Bought And Sold....I Got Your Soul! |
#23 |
A fat wallet.
Silence is golden, duct tape is silver. - Scott |
#24 |
Besides three rollaways of hand tools I regularly use
Various air tools (ratchets, impact, cut-off, nibbler, punch/flanger, etc) Miller MM210 mig welder Miller Syncrowave 180sd tig/stick welder Hypertherm 380 plasma cutter 40" bending brake Bead roller JD2 M3 tubing bender and many die sets Pro-tools tubing notcher Various levels, measuring devices, fab tools Horizontal band saw Milwaukee 14" chop saw Sawzall 4 Hitachi 4.5" grinders (two with cut-off wheels, 2 with flap discs so more than one person can work @ same time) Hitachi 1/2" and 3/8" drills Engine hoist Sandblast cabinet 40 gallon parts washer A/C unit, fans Three floor jacks (one aluminum lightweight unit) 4- tall 6 ton jackstands 4- short 4 ton jackstands Lots of safety equip. (glasses, face shields, ear prot., gloves, 1st aid stuff) Pioneer Elite receiver, Sirius satellite radio, 4-Niles OS10 spkrs and a powered sub for drowning out work noise ![]() And other small items I am forgetting Last edited by pbmcauliffe; 09-16-2004 at 01:29 PM. |
#25 |
Thanks for all the advice!
![]() Here's what I DON'T have but need: Enough storage Oxy/Acetylene torch for cutting Mig Welder Hydraulic jack or jack stands. Yeah, I know, basic stuff. Table saw for bed work Drill Press Sandblast cabinet - but I do have an old freezer, an air compressor, and 90 miles away there's a beach with pure white sand. $20,000 to get a minimal home workshop set up properly |
