Old 09-15-2004, 01:44 PM   #1
toddtheodd
The oddest Todd around
toddtheodd's Avatar
2inch front drop springs
I've got a set of 2" drop springs for the front of my c-10.
I have a small block in my truck.
I am not sure if these are for the BB or the SB. What would happen if I put 2" BB drop springs on my SB truck?
Todd
toddtheodd is offline   Reply With Quote
Old 09-15-2004, 02:03 PM   #2
Joe67
67 is sold
If you use BB springs in a non-BB truck, I'd guess the truck would sit up a little higher
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 09-15-2004, 03:08 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Everyone just sells generic 2 inch drop springs. ECE is the only place I've ever heard of that specifies which engine on drop springs.
Be prepared to be dissapointed Todd. Your stock springs are likely sagged a good bit by now, so the 2 inch drop probably won't be all you wanted it to be. You're possibly already sagged an inch or two.
Old 09-15-2004, 03:49 PM   #4
toddtheodd
toddtheodd's Avatar
I do not think these are the original / correct springs on my truck. It sits pretty high with 27" tires. I think a po may have put lift springs in it because it used to also have bigger tires. (Why do people run "big" tires on a 2wd??? )
Todd
Old 09-15-2004, 04:16 PM   #5
dallas71
dallas71's Avatar
poor mans 4WD "LOOK" Todd don't you know that trick???
dallas71 is offline   Reply With Quote
Old 09-15-2004, 05:12 PM   #6
toddtheodd
toddtheodd's Avatar
I know that it "looked" like my truck could drive over anything, but in reality it was a one wheel wonder.
Old 09-15-2004, 05:47 PM   #7
stickshift_or_walk
Left Foot Functioning
stickshift_or_walk's Avatar
Originally Posted by toddtheodd
Why do people run "big" tires on a 2wd??? Todd
Easy. Ground clearance. I drive "off road" almost daily, and spend lots of time on what I call roads, but the SUV manufacturers would call "rough conditions, not covered by warranty". "Big" tires often prevent undercarriage damage, and mean the difference between going forward and backing out.
You'd be surprised where an experienced off-road driver (farmer, rancher, etc) takes his 2WD. Many times, 4WD just means a bigger tractor/wrecker to pull you out...
Besides, there are cheaper ways to fill up our big ol' wheelwells than 20" rims...
SSOW
69 C10 (#1 son's ride)
72 C20 (Dad's farm truck)
82 K30 (Ex - brush pumper project)
stickshift_or_walk is offline   Reply With Quote
Old 09-15-2004, 06:35 PM   #8
toddtheodd
toddtheodd's Avatar
Well... I'm not an off roader. I'm a city boy. My truck is going to be a green light screamer. Not much use for big wheels or a suspension lift when you're on concrete.
When I get home I will measure just how far it really is from the ground.
I know that stock height on stock rims would put it at 32" in the front and 34" in the back.
Old 09-15-2004, 07:03 PM   #9
71Chev
71Chev's Avatar
Not everyone sells a generic drop spring. We have a performance coil spring shop custom wrap our springs to the truck specs they are to be used in. We require amount of drop, long or short wheelbase, engine, transmission, and if equiped with a/c or not. The one down side is since they aren't generic shelf stock, they can take up to 14 days to ship depending on where the shop is in their heat treating process.
If they came from us big block drop springs will make a small block truck sit a little higher.
Les
@GMCPauls
71 Chevy CST Long Fleet 350/350/3.07 leaf rear.
71Chev is offline   Reply With Quote
