Old 09-15-2004, 06:26 PM   #1
n737nc
How to keep motor cool after you shut it off???
My motor runs about 190* when it is running. But as soon as I cut it off, the temps rise to about 220*. Is there anyway to keep it cool after the ignition is cut off?
n737nc is offline   Reply With Quote
Old 09-15-2004, 06:32 PM   #2
70c10
67-72 Addict!
70c10's Avatar
Thats normal because it's not circulating when it's off. You could always pop the hood open to help cool it down.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 09-15-2004, 06:34 PM   #3
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
electric fans and electric water pump. have them on a temp sensor to kick on and off together??? probably work but not good for driving
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 09-15-2004, 06:49 PM   #4
1972C10
1972C10's Avatar
Thats kinda how it works Water that hanst gone trough the radiator comes back into the engine it will go right back down once its started up.
1972C10 is offline   Reply With Quote
Old 09-15-2004, 07:33 PM   #5
shortymac83
hmm...
shortymac83's Avatar
When I had my 195* thermostat in the Olds, the temperature would spike to 240* on hot days after shutting it down, and sometimes even hit 220* when driving it in the city (!). This is why I put the 180* thermo in there. STill spikes when I shut it down, but as soon as you start it up again, it'll cool off. It's normal.
1983 Oldsmobile Delta 88
1967 Chevy C-10 stripper
www.fcrperformance.com - wanna go...faster? talk to FCR.
shortymac83 is offline   Reply With Quote
Old 09-15-2004, 07:37 PM   #6
Jeremy_5
Truck addict
Jeremy_5's Avatar
same thing happens to me, I assumed it was normal. But how come in newer cars like my 2000 chevy it never happens. It always stays at normal operating temp (unless its warming up).
1956 Chevy Napco
1972 Cheyenne Super
1970 K20
Jeremy_5 is offline   Reply With Quote
Old 09-15-2004, 07:47 PM   #7
68w/sbc406
68w/sbc406's Avatar
i dont think the newer gauges work when the ignition is off
Old 09-15-2004, 08:04 PM   #8
Blazer1970
Blazer1970's Avatar
Totally normal, nothing to worry about.
Blazer1970 is offline   Reply With Quote
Old 09-15-2004, 08:46 PM   #9
cdowns
cdowns's Avatar
you could always try parkin it in an igloo
