Old 09-15-2004, 06:41 PM   #1
angelsairman
Future Owner
angelsairman's Avatar
Question Headers?????!!!!
I have a 2WD 1971 C-10 that i just put a 350 in with a TH350, column shift.
Anyone have any suggestions on what headers will give me the least headaches on installation and not to pricey??
Its not the end result that counts most...its the journey along the way that's most rewarding
My truck doesn't leak, it just marks it's territory
angelsairman is offline   Reply With Quote
Old 09-15-2004, 06:47 PM   #2
toddtheodd
The oddest Todd around
toddtheodd's Avatar
I had no problems installing my hooker long tube headers. They were like $200 though.
toddtheodd is offline   Reply With Quote
Old 09-15-2004, 06:52 PM   #3
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i picked up a set of long tubes for 20 bucks at the swap meet(not sure what brand). just made sure the front tube went up and over the 2nd and 3rd to clear the motor mounts
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 09-15-2004, 07:16 PM   #4
crazy longhorn
Fabricate till you "puke"
Hooker Comps....#2452 (painted, $140 through Jegs)will fit stick or auto, & the collectors dont show but about 2" below the frame rails(good on a lowered truck) crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-15-2004, 07:55 PM   #5
badpeanut
Not a bad nut after all..
badpeanut's Avatar
I used the Summit brand (~$100) on my '71 4x4 (350/TH350) with no problems other than having to make a small notch in the header flange to clear the temperature sending unit. Both exhaust manifolds were cracked on this truck.
Did you decided to go with headers rather than find that passenger side manifold?
badpeanut is offline   Reply With Quote
Old 09-15-2004, 08:01 PM   #6
WRMZ71
Cause the Chicks DIG IT!!
WRMZ71's Avatar
Yep, the Summits and i got mine from Autozone. They are the flowtech's which are a division of Hooker if i'm correct. They were like 80 bucks and i didn't have one problem putting em in.
WRMZ71 is offline   Reply With Quote
Old 09-15-2004, 08:37 PM   #7
Z28Owner
Z28Owner's Avatar
My bro put flowtechs's on his, no prob's, I went with them also. Had no problems, cept for the 30 year old motor mounts let the # 2 header hit the frame. Changed them out. fit great, only plug I cant get to without a socket is # 6 , just use a stubby end wrench. No leaks either.
1971 LWB Chevy C-10
350/350 3:42 eaton
Z28Owner is offline   Reply With Quote
Old 09-15-2004, 09:00 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Hooker super comps.
I'll never buy cheap headers again.
Old 09-15-2004, 10:36 PM   #9
67chops
67chops's Avatar
does anyone know if a set of block huggers would fit on a sb in the 67. i was thinking about picking a pair up because they are relatively cheap.
-Chops-
67chops is offline   Reply With Quote
Old 09-15-2004, 10:46 PM   #10
68w/sbc406
68w/sbc406's Avatar
be careful about where the dump is, could be in the way of motor mount
Old 09-15-2004, 11:43 PM   #11
bigjimzlll
bigjimzlll's Avatar
if you have rams horns now, why switch to block huggers? you wont gain much if any in HP or torque
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 09-15-2004, 11:55 PM   #12
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Block huggers will not fit! I tried them on mine and they hit the motor mounts. Try the '70's Chevelle shorties...they will clear. I really like the torque I got with long tube headers but they are too low for a slammed truck! I really noticed the change in low and mid-range torque when I lowered and switched from the Hedman long tubes to the Dynomax shorties.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 09-16-2004, 01:48 AM   #13
67chops
67chops's Avatar
do you suggest i go to long tube headers then?
-Chops-
Old 09-16-2004, 02:08 AM   #14
poff
I just put Hedmann Elites on my truck. They were like $300 at Summit but they have really thick flanges. my biggest problem with headers is the collectors always leak because the flanges bend. I did have to dent them for the Z-bar though. The tubes seem pretty thick too. I would also suggest Stage8 bolts, they are really nice and if you have accessories they will send you extra bolts in the length you need for free.
'70 K-20 San Diego, CA
poff is offline   Reply With Quote
Old 09-16-2004, 04:42 AM   #15
Longhorn Man
The hookers don't hit the ground onless your ride is slammed...and even then, it isn't much.
Old 09-16-2004, 07:29 AM   #16
68C15
blood type; Retumbo
68C15's Avatar
Hedman shorties if you are going down. otherwise Hedman long tubes. the long ones are about $120 & I believe the shorties are close to the same money. they both have thick tubes which suppress that tinny sound I have heard from the flowtechs. by all means get those Stage 8 locking header bolts. you will NEVER have a bolt come loose. I also think all the new hedmans come with a "bell" style collector instead of the old fashioned flat leaker.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 09-16-2004, 11:07 AM   #17
70short
I bought Hedman shorties for mine. I plan on ending up with A 4/6 or lower drop when I am finished. They were 135. delivered to my door from summit.
Gary
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
