Old 09-16-2004, 09:28 AM   #1
oldcarbuff
will late model six lug rims fit on a 67?
I drool over the cheap prices charged for late model six lug rims/tires that are available as take-offs from conversion places. Specs for these looks like they would fit, but I haven't pulled a rim off my truck to see--I'm sure someone has tried these already--do they fit? Thanks!
OCB
oldcarbuff is offline   Reply With Quote
Old 09-16-2004, 09:55 AM   #2
SCOTI
SCOTI's Avatar
I got some late model 6 lug whels to put on a 67 rolling chassis & much to my suprise they didn't fit. The hub flange for the early 6 lug wouldn't let the late model wheel sit flush. These were aluminum so the steel could be different.
I do know that mid year model 15x8" 6-lug/4wd steel ralley wheels will fit w/o a problem.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 09-16-2004, 10:06 AM   #3
Putter
More Cowbell....
Putter's Avatar
Yes and no. Right out of the box...NO. But, you can have a machine shop enlarge the center hole so they will fit over your flange that Scotti mentioned. I am not sure about the steel/chrome ones. Oh, backspacing will be close (what I have heard). Some user's have been forced to use spacers.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 09-16-2004, 10:14 AM   #4
gr8scott51
gr8scott51's Avatar
This subject needs to be put in the FAQ section, as it gets asked by everyone (including me when I first got my truck). The bolt circle is the same, the center hole is too small and the backspacing is wrong. Standard backspace is 4-1/2". Seems like someone mentioned that the steering arm rubs on the rim, too.
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 09-17-2004, 02:19 PM   #5
curbyk
69 C-10 project
curbyk's Avatar
I asked the same question a few days ago...I called the Chevrolet dealer and asked them they told me if bolt pattern was the same they would work...NOT...different hole size, you can get spacer/adapters from several places including E-Bay, I just got mine and havent tried them yet. Will post results when I do. The back spacing may be an issue also.
curbyk is offline   Reply With Quote
Old 09-18-2004, 01:29 AM   #6
oldcarbuff
thanks curbyk. I was just thinking of the same thing--a small spacer or adaptor might be enough to get the backspacing problem taken care of and simultaneously might be thick enough to cure the flange problem too. When you find out your results, please share!
Joel (OCB)
Old 09-18-2004, 02:23 AM   #7
krue
Designated A-hole!
krue's Avatar
I will see what we can do about getting this question in the FAQ section.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 09-18-2004, 09:38 AM   #8
Inspector722
Fixing my 67, & loving it
Inspector722's Avatar
The back spacing is off by 1.5". And they will rub depending on your set up in hard turns on the 16" rims. I am not sure on the 17" or larger. Wheel spacers work but not all wheel spacers have the center hole large enough for our trucks. You will have to ask before you buy. Most stuff is made for the new trucks now days.
Email address- inspector722@aol.com
Zip Code- 77611
Shipping- DHL & USPS
Working on: 67, large back glass, 307 V8, 200 4R, 3.73 rearend, Short Stepside Bed
Inspector722 is offline   Reply With Quote
Old 09-18-2004, 10:54 AM   #9
SCOTI
SCOTI's Avatar
Remember that these trucks that have original 6-lug hubs have very short 7/16" studs as well. I was going to use some washers for the alum wheels I had (disclaimer: these wheels were only for rolling the chassis around the driveway).
Once I stacked a couple of 1/16" thick washers to space the wheel out there wasn't enough stud left to thread the lugnuts. If you were to use spacers/adapters, you'll prob need to get longer studs. Do they even make longer 7/16" studs?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 09-18-2004, 03:11 PM   #10
hotrodtroy
hotrodtroy's Avatar
Talking
Race studs can be pressed in and they are alot longer. my.02
'72 C-10 w/
'68 Large Journal 327cu.in.
"It's o.k. to dream about what you want to do, until you start doing what you are meant to do." Line from "The Rookie"
hotrodtroy is offline   Reply With Quote
