Old 09-16-2004, 11:41 AM   #1
TIMSPEED
TIMSPEED's Avatar
$700 a good deal for Eaton Posi Parts/Labor?
I'll be getting an Eaton Posi installed prolly middle of next week, just wanted to see if you guys thought it was a decent deal.
That guy on Ebay (GearsRUs; Wayne Grubbs) said for $425 shipped to my door, he'd get me the Eaton Posi, & Install kit.
A local shop, who came recommended, quoted me $275 to install the posi.
Sound like a decent deal to you guys?
That guy on Ebay is a real class act, E-mailed me back right away, and was totally upfront with the pricing. (Thanks for recommending him, PhantomDually) The Eaton has the 400# spring pack inside it. (Which is what my friends said I want)
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 09-16-2004, 11:48 AM   #2
cochino12
It followed me home?
cochino12's Avatar
Wayne is the man I bought my posi from him also. To make a story short Wayne could have screwed me for over $800 but was a stand up guy and called paypal to straighten it out for me. Anyway that doesnt sound like too bad of a price, I'm sure you could find someone to install it for less but cheaper is not always better. No more peg leg burnouts now huh
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 09-16-2004, 01:19 PM   #3
TIMSPEED
TIMSPEED's Avatar
Exactly! Now that I'm back working, I'm going to get this truck finally finished up. Get the Posi in, then fuel cell, put on the drag radials, and see if I can't click off some 14's.
See Them Here
Old 09-16-2004, 01:40 PM   #4
gldevall
gldevall's Avatar
That's where I got my posi and gears from. Super guy. I would buy from again if I needed anything. On the $275 to install, you may want to check around a few more places.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 09-16-2004, 01:51 PM   #5
TIMSPEED
TIMSPEED's Avatar
I DID call around. Every other place wanted $350. The place that wants $275, built a friend of mine's 700R4 (that lives behind a 500rwhp LT1 Camaro).
See Them Here
Old 09-16-2004, 11:40 PM   #6
79Silv4x4
Workaholic
79Silv4x4's Avatar
WTF? Why is this post necessary other than to increase your post count (once again!!!!!) You checked around, found a place that is $75 cheaper than average and you have a positive personal recommendation/experience with the guy
79Silv4x4 is offline   Reply With Quote
Old 09-16-2004, 11:56 PM   #7
TIMSPEED
TIMSPEED's Avatar
Do you just LIKE to post on my threads and talk smack? I mean, come on, you ever heard "If you have nothing nice to say, don't say anything at all."
See Them Here
Old 09-17-2004, 02:44 AM   #8
plumbcut
california fill
that sounds like alot of money to setup a R&P.. Id personally spend a weekend doing it myself and learning. Its not rocket science! Say it takes him a full 8hrs to set it up, which it wont.. thats $26 an hour! i think I could have it setup in hrs for less tha $275 in parts. but thats just me....
plumbcut is offline   Reply With Quote
Old 09-17-2004, 09:33 AM   #9
RockHQ
ROCKET POWER!
RockHQ's Avatar
You ever done that kind of a job yourself? Setting up a ring&pinion is no rocket science but it does require a keen understanding of what really needs to be done to do it right the first time.
Btw, Tim i highly recommend you do a quick search on the PowerTrax No-Slip. Read the online reviews it has received and give it a good thought. It requires no alterations to the stock carrier&ring&pinion, and no special tools to install it. You could do it yourself in about 4 hours and spend a lot less money which could be used for something else (No need for install kit, cheaper than the Eaton, no need to have it set up by a pro). The No-Slip doesn't make that annoying sound like the old Lock-Right, it's 100% locker when engaged and has no clutch plates to wear or cones to bottom out.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 09-17-2004, 09:46 AM   #10
RockHQ
ROCKET POWER!
RockHQ's Avatar
One other thing that's been mentioned before but i'll say it again:
1. The eaton requires a limited slip additive to the gear oil to reduce friction
2. The powertrax does not
3. While regular gear oil is available everywhere, the posi additive is not
4. With the eaton, every oil change costs extra
Old 09-17-2004, 10:11 AM   #11
Greenlee
Greenlee's Avatar
I had a Nissan Xterra with limited slip and got the gear oil with the additive at Autozone. Here in the states I think it is pretty much available everywhere.
Greenlee is offline   Reply With Quote
Old 09-17-2004, 05:45 PM   #12
SanitysBane
so you don't need to run any special rearend grease with a locker do you? i hope u don't...
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 09-17-2004, 06:18 PM   #13
RockHQ
ROCKET POWER!
RockHQ's Avatar
Unless the manufacturer of the locker specifies otherwise, regular GL4 75W90 will do the trick. A locker like the No-Slip does not use any clutches or a cone forced against the carrier. Posi-Traction or posi is common lingo for these, which base their ability to limit wheel spin on exact friction properties of the clutch plates (or cone), the carrier itself, the spider gears and the gear oil.
Old 09-17-2004, 08:37 PM   #14
plumbcut
california fill
you'd be hard pressed to find straight gear oil that didnt meet the api spec for clutch type posi's.. i think the spec is GL-5? The tube of additive is also available but most of the quart or 5 gallon size come pre-mixed for any type of axle...
pc
Old 09-17-2004, 09:39 PM   #15
phantom dually
Project92 SWB stepside
phantom dually's Avatar
Are you gonna change the gear also?? If so now is the time!! There is a guy here at home that will do a rear for $125. Thats gears posi and bearings and have it back to you next day. He also does great work. He is a retired machinist and loves cars and trucks. The only catch is you have to pull the rear and bring it to him.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448
phantom dually is offline   Reply With Quote
Old 09-17-2004, 11:47 PM   #16
1972C10
1972C10's Avatar
Yeah it sucks laying under a vehicle to set up a R&P Thats what you gotta love about Ford 9"
1972C10 is offline   Reply With Quote
Old 09-18-2004, 04:51 AM   #17
TIMSPEED
TIMSPEED's Avatar
Ahh ha, that's always the catch to cheap jobs. I'm just going to drive my truck over to the shop, with my parts in the seat, and then pick it up when it's done, and leave TWO black marks.
See Them Here
Old 09-18-2004, 02:30 PM   #18
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Dont pay extra for the warranty, cuz they probably wouldn't honor it after something like that.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 09-18-2004, 04:39 PM   #19
phantom dually
About the black marks.........if you want it to last, break it in the right way and change the fluid after about 500 miles.
Old 09-18-2004, 06:15 PM   #20
76HighSierra
DAMN, I love Big Blocks!
76HighSierra's Avatar
....and leave TWO black marks.
Or, a big BOOGGGGGGGGGGG and lots of spitting and sputtering. You never know how that old bird will behave with traction.
Marc Bona
Hobbs, New Mexico
1976 1/2 ton GMC High Sierra.
454 c.i.d./ TH400. *Soon to get a mild warming over.*
3.40 rear.
76HighSierra is offline   Reply With Quote
