Old 09-16-2004, 01:08 PM   #1
loblazer
loblazer's Avatar
Question Shift indicator sloppy, help?
The shift lever/indicator on my 1980 Blazer is real sloppy. I can almost move it from drive to neutral without coming out of gear. Are these adjustable or do I need to install a new column?
Thanks, Doug
loblazer is offline   Reply With Quote
Old 09-16-2004, 01:13 PM   #2
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
plastic bushings
Doug, the first thing I would check out is the plastic bushing in the linkage, they my be worn out and are easy to replace. If memory serves me correct there are 2, one near the firewall and one down close to the tranny.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 09-16-2004, 01:18 PM   #3
loblazer
loblazer's Avatar
Great Jeff, thanks. It affects my backup lights too so is a real pain.
Doug
Old 09-16-2004, 02:14 PM   #4
elvis50138
elvis50138's Avatar
and a thank you from me as well. I'm having the same problem.
elvis50138 is offline   Reply With Quote
Old 09-17-2004, 12:28 PM   #5
loblazer
loblazer's Avatar
Thumbs up
Thanks Jeff;
I checked last night and the rod at the firewall has no bushing, just flopping around. Going to call my GM parts buddy and order top and bottom ones.
Doug
Old 09-17-2004, 12:41 PM   #6
TexasJeff
TexasJeff's Avatar
Glad I could help guys
TexasJeff
Old 09-17-2004, 01:34 PM   #7
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Part numbers would be nice if you can still get them.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 09-24-2004, 05:49 PM   #8
loblazer
loblazer's Avatar
Thumbs up
Ok, got my parts in.....what a difference!
GM #1394293 is the upper sleeve kit, contains bushing and spacer. $3.20
GM #1377083 is the lower plastic bushing $2.50
These are Canadian prices so you guys can probably buy the whole works for about $4.00
Thanks again for the info and tips, much appreciated.
Doug
Old 09-24-2004, 07:29 PM   #9
MylilBowTie
Right turn Clyde
Thank you =o)
