Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
replumbed my trans cooler(PIC'S)
I replumbed my trans cooler this week and decided to change things a bit.
1st,the way it WAS plumbed not only looked bad but it leaked. I have a 11"X11", 28,000 GVW,stacked plate trans cooler that I run in conjunction with the trans oil cooler in the radiator.I'm cooling a TCI 700R4 transmission. Here's the flow path of the oil. lower port is the output.It goes to the stacked plate cooler 1st. From the stacked plate cooler it flows into the cooler in the rad. From the radiator cooler it flows back to the trans and enters via the top port of the 700R4. In addition to bending up the lines to make them look nice I rerouted them to the outside frame rail and isolated the hard lines with rubber lines. I used the rubber lines when I was going from one body part to another.An example is from the frame rail to the rad. core support or from the trans to the frame mounted hard lines. Doing it this way will accomodate for any shifting or movement between the said body components in flexy situations. Anyhow,enough talk...let's get to the pic's ![]() I bent up the 5/16th hard lines with your run-of-the-mill tubing bender. I double flared the connections with a 45deg. double flaring tool. I did get a new toy and utilized it on this project. It's a pneumatic hose crimper.It can be used to make hydrolic and A/C lines.I've now done both with it ![]() It a Mastercool hydrolic crimper. ![]() Here's the beginning of one of the hoses I made.Two tube ends(double flared),Transmission oil rubber tubing,crimp sleeves(furrels), and to make it look cool some stainless braided sleeving. ![]() After messuring things and cutting to the right length I slide the braiding over the hose and tapped the end off with electrical tape.I then slide the crimp sleeve over the hard line ends. ![]() With a little trans oil smeared onto the hard line I slid the rubber line onto the hard line. Then with a 1/2" wrench I coaxed the furrel over the hose and braiding.This was a little tough as the braiding increases the O.D. and the furrel is sized to fit JUST over the rubber tubing. ![]() Next was the fun part.I got to use my new hydrolic crimper and crimp on the furrels over the tubing. You 1st insert the right sized teeth into the crimper and then lock it closed with a saftey pin. Then insert the tubing into the jaws and center the furrel in the teeth. ![]() Then close the valve on the crimper and pump the handle.It slowly closes the jaws and crimps the ferrel onto the hose. ![]() Open the valve to release the jaws and take out your newly crimped hose.Looks GOOD :thumb: ![]() This particular line goes from the trans output to the hard lines on the frame rail. ![]() Making sure I didn't drill into the fuel and brake lines on the inside of the frame rail I drilled two 3/4" holes for the new hard lines to pass through. I used a wire coat hanger to get the shape and mark the bends I needed to make to the hard lines. I then mounted the hard lines to the outside of the frame rail with some 5/16th tiedowns. ![]() These two lines go into the trans and connect to the two hard lines I passed through the frame rail. ![]() I mounted the cooler and proceeded to bend up the hard lines that will feed it. ![]() Here I've bent up one of hard lines feeding the cooler and connected a rubber line to one end. ![]() I also made new lines going to and from the rad. trans oil cooler. The top line connects to a hard line on the frame rail and sends the trans oil back to the transmission. The bottom line is coming from the stacked plate cooler and feeds trans oil to the rad cooler. ![]() I fed the feed and away lines for the stacked plate cooler through the rad core support.All the lines were secured to the frame rail or rad core with the appropriate fasteners. ![]() I attched the rubber lines to the stacked plate cooler and clamped them down with some hose clamps.I added the two bottom brackets to help support of the stacked plate cooler. ![]() Here are the connections at the frame rail. ![]() Here it is all done,well...minus one of the rubber hoses.I hadn't connected it yet when I took the pic. ![]() And that's that! It looks good now,is solidly mounted and DOES NOT leak. ![]() Hope this can help someone in the future.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 09-17-2004 at 07:37 AM. Reason: spelling |
its all about the +6 inches
It's all in the details, and it looks pretty darn awsome.
One of my kids. Cute eh?
That was informative to say the least. I like that crimper. What brand and model is it? That looks like something we could use at work. We have a big monstrosity that is overkill for what we do.
What did you use to bend the hard lines? When I replaced my brake lines, I used those springs things that you slide over the tube. They did not turn out as well as I would have hoped. I double flared them and that turned out great. But I also had a high quality tool from work. Mike
If a kid asks where rain comes from, I think a cute thing to tell him is “God is crying.” And if he asks why God is crying, another cute thing to tell him is “Probably because of something you did. John 3:16 2006 Chevy HHR 2000 Dodge Durango 1985 Jeep CJ-7 1970 Chevy Pickup |
Great job! It looks good!!
1969 Chevrolet SWB Stepside 1959 Chevrolet apache * Sold 1967 Prostreet Chevy SWB Fleetside *Sold 2014 1/2 ton Crew Cab Chevrolet 4x4 |
Lovin' Life in Miss.!
http://www.acsource.com/index.asp?Pa...ROD&ProdID=156
Cut and paste the above link to your browser. I do not know how to post links yet. This site has the cheapest non contact laser thermometer around! I've bought lots of stuff from them but not the crimper. I can't part with almost 5 bills for a one time project... ok 2 or 3 time project. Bobby, your set up looks great. Rich
The truck... you hear that? No really, you did hear that?!!! |
Wow! guess I do know how to post links!
The LuvShack Garage
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
I used a generic hand tubing bender.It kinda looks like this.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
Life is a gamble
BobbyK, That was one of the most informative posts I've ever seen.
That Crimper is NICE! You must be a serious Tool guy.
1970 Orange CST C-10 w/350, posi, Longbed The torpid artist seeks inspiration at any cost, by virtue or by vice, by friend or by fiend, by prayer or by wine. -- Ralph Waldo Emerson |
![]() Join Date: Mar 2004
yes thank you for the awsome informercial. i want one now too!
ondrew |
Still drivin' a Rat Rod
Almost makes me wish I had an automatic just so I could bend some nice lines like that
![]() Almost:p Great job on the lines.I always had to use hose clamps and rubber line ![]() That is beautiful.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
#12 | |
Re: replumed my trans cooler(PIC'S)
#13 |
That is cool, very cool!
67 Short Step, 355, 700R 4.11 posi rear, 4/6 drop Discs on all 4 corners. Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=219094 |
#14 |
Gorgeous work... I could really use that crimper for several projects I have planned. But, I need to be able to afford the parts for them first! lol.
Im gonna keep this one saved
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
#15 |
Gettin By on Gettin By
Just what i needed to know. Thanks for the pics.
