Old 09-17-2004, 04:15 AM   #1
Jetmech727
Thumbs up New to the Game (need help)
I recently purchased a 1970 chevy truck 1/2 t. I am going to convert it from a man to auto trans. Could you please enlighten me as to what I will need to do this job (parts wise). Also will I have to have a double hump cross member to run duel pipes or does the standard cross member work ok? Thanks in advance for the help.
Jetmech727 is offline   Reply With Quote
Old 09-17-2004, 04:31 AM   #2
Blue Beard
Blue Beard's Avatar
You need to figure out which trans you want to use first.
350, 700r4
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 09-17-2004, 04:42 AM   #3
dyingdeadman
dyingdeadman's Avatar
also need to know if you want floor shift or colum shift, if you want automatic on the colum you probely will have to change that out too.
72 GMC sierra 3/4 ton 402 bb
68 GMC 3/4 ton
2010 camaro rs: daily driver
dyingdeadman is offline   Reply With Quote
Old 09-17-2004, 04:49 AM   #4
Jetmech727
I will be using a 350 trans for the simple fact that I have one already. What is the most most economical way to go with the shift (floor or colum) really doesn't matter to me. I just want it to be right. I going to a swapp meet this weekend and I really only have a rough idea of what I need.
Old 09-17-2004, 06:31 AM   #5
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Get a auto cross member, auto steering column/linkeage, radiator for an auto for cooling will need cooling lines also. On the cross member I believe the manual tranny cross member will not work. Not sure on the rear driveshaft length either.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 09-17-2004, 07:41 AM   #6
MACKL
Almost done!
MACKL's Avatar
Drive shaft length is the same, the yoke is different. If you use the manual yoke, (it will fit), you will have tranny fluid run out all over you drive way. The manual yoke has some kind of a vent hole in the center. I found this out the hard way. Really messed up my driveway. The wife almost killed me.
The low hump will work, the cross member is the big difference. Removing the manual cross member is a pain.
locating trans cooling lines give most people problems too. Watch for them at the swap meet or you can bend your own. Good luck...Kelly
The 1970 SWB Project
Removed 6cyl manual trans, manual everything
V8-350
Auto/PS/PDB
Blazer Fuel Tank
Behind the Marker Light Fuel Fill
MACKL is offline   Reply With Quote
Old 09-17-2004, 08:10 AM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You can't blanket say the driveshaft wil work without changing the length.
There are 3 different lengths of tailshafts on Th350 trans, 6, 9, and 12 inch. It depends on which length trans he has to use.
Old 09-17-2004, 09:20 AM   #8
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
A lot of times it's cheaper to buy a wrecked truck with all the stuff you need for a hundred buck or so than to track all the stuff down.
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 09-17-2004, 10:22 AM   #9
Putter
More Cowbell....
Putter's Avatar
I agree with brainshild on that one. If you have a complete donor, it helps out.
Oh, welcome from Central Mississippi.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
