Old 09-17-2004, 04:51 PM   #1
FormerMember
Instrument lights
Ok, so how do they work?
I have a new autometer gauge cluster going in, can't get lights from the light switch.
Anyone have a wiring diagrahm for a 70 Chevy C20.
I am slowly but surrly rewiring this sucka.
FormerMember is offline   Reply With Quote
Old 09-17-2004, 09:30 PM   #2
Lgriffin
I don't have the Chevy manual do have the GMC manual for 70. According to the manual there is a grey wire from the instrument light fuse in the fuse panel to the flex circuit connector on the back of the instrument panel. There is also a dark green wire from the light switch to the same fuse. If you look at your light switch connector there are 3 terminals in a row the only 3 terminals in a row. The middle wire on those 3 terminals is your dark green wire for the instrument light fuse. Check near the fuse for a spade terminal it might be for an light not in the instrument panel. Hope this helps.
Larry
68 C20 327/465 daily driver 4:56 och!
63 C20 292/420 Camper truck Detroit Locker 4:10 posi
65 C10 ? /powerglide Custom Cab AC,PB,PS,4xflasher
70 C10 250/3spd org/Gauge dash,Wood bed, 4Sale$1300
Lgriffin is offline   Reply With Quote
Old 09-17-2004, 10:05 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Yes, there is a spade terminal on the fuse box that is switched with the dash lights...the one marked cluster feed.
