love my truck
How do you hook up the accelerator rod to the edelbrock carb? Do I have to instal the bracket from the other carb? Does anyone have any pix
its all about the +6 inches
I drilled out the hole on the carb, no problem since
I might have a pic somewhere. ------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
Yup, here it is...
![]() ------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
I used a linkage connector from holley..its aboout 5/8" round with a threaded hole and a tappered shaft to fit in the carb..the tappered part has a hole though it for a cotter pin...I think it was about 10 bucks
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
love my truck
Thanks you guys for your help. I gess I panic for nothing. I posed this question an got 3 responces and a picture in less than a 1/2 hour, isint this site grate?
Hey longhorn...you got a pic with a detent cable hooked up..trying to figure the best throttle spring placement
detent cable?
wait...a kickdown cable, or a '71/'72 cable throttle...either way, i don't have a pic. The kickdown should be where my throttle return spring is hooked,a nd oneday, it will be.
This help ya Bigjim. The stud the tv cable hooks to is sold seprately by Edlebrock.
[img]http://communities.msn.com/_Secure/0MgAAAEUQXo1N5bSbIdaPdzGuJ9aA!*JS1hpUnjzE4i8mtXedWXEZjD3qKcgCnmOrF!7pwyMA1D6zS0sss386Zg/tv-linkage.JPG[/img] ------------------
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
Yup that helps....Ive got mine almost like that...cant believe I didnt use the intake manifold bolt to hold the spring holder thingy..I used the thermostat housing bolt. I spent a weekend trying to put the spring in the rear...with no luck..Thanks
It does look better to the rear huh? I been trying to figure how to run it this way when the kickdown goes on.
