Old 09-18-2004, 04:40 PM   #1
treyvette17
need some engine swap help
I am putting a 67 pontiac 400 in my 72 gmc shortbed and cannot figure out how to mount it or what mount stands i need. I have the one bolt mounts and they line up to the mount stands that were in the truck, but the engine seems to be sitting to high, at an angle. What do I need to do...I have have exhausted all efforts!!
treyvette17 is offline   Reply With Quote
Old 09-18-2004, 08:45 PM   #2
roj2323
build custom engine brackets. you are after all putting an engine in a truck it wasn't designed for.
good luck,
ondrew
roj2323 is offline   Reply With Quote
Old 09-18-2004, 09:35 PM   #3
Brainchild
Still drivin' a Rat Rod
Brainchild's Avatar
I would start by going to teh parts store,and looking through the mounts avalible for that engine,and see if you can find something close to the pads chevy uses.Bolt them on the engine,and lower it into the truck,move the frame stands under them and see what you can do to make it fit.
Pics are invaluable in this situation
Obviously you want it sitting level,and pretty low,but there is a ton of clearance between the hood and breather.
hope this helps
Rusty Member #13872
Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#*
71 GMC LWB
49 Chevy
85 Chevy G20
Check out my website
Brainchild is offline   Reply With Quote
Old 09-18-2004, 09:49 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Go to the junk uard, and get the frame mounts from a 73 - 87 truck. The Pontiac engine will fit down low in these, but you will need to fab a spacer to go between one mount and the frame mount. Mine had lug nuts, so figure about a 1/2 inch spacer in there.
My one ton had a Pontiac 350 in there when I got it. You'll also need to run the fuel line on the other side of the chassis...I would just redo it from teh tank...it isn't very much work. For the battery, you'll need to moveit to the other side of the engine compartment. You can get the optional Aux battery try which mounts on the driver's side pretty much just like the one in your truck now. You'll need to extend the alt harness most likely, depending on what was in your truck originally.
You do all this, it'll look like the engine belongs there.
Old 09-18-2004, 10:02 PM   #5
evanslein
I think I will have to get big block frame mounts from a 73 and use the horizontal bolt pontiac motor mounts and it should fit. What do you mean by putting a spacer between one of the mounts??? thanks
evanslein is offline   Reply With Quote
Old 09-18-2004, 10:11 PM   #6
Longhorn Man
The frmae mounts that were in mine had 6 cylinder, and 8 cylinder stamped into them by two sets of holes...so this was a common frame mount.
When the Pontiac motor is sit that low into the frame...to where it looks like it is supposed to be there, the motor mounts won't quite reach these frame mounts. So the P.O. placed lug nuts between the frmae mount and motor mount on one side. This shifted the engine a little to the drivers side, which also made spark plug access easier on the passenger side by the heater box.
Old 09-19-2004, 09:16 AM   #7
Blue Beard
Blue Beard's Avatar
If the later mounts are used sitting lower, will there be any problems with the exhaust down between the frame rails?
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 09-19-2004, 09:31 AM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I doubt there will be any cleaerance issue's blue as andy had a pontiac motor in his ride I can't see andy giving advise to make one part work and not the other I am sure it would fit with exhaust and have no problem's..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-19-2004, 05:12 PM   #9
Longhorn Man
Yeah, exhaust was fine. The engine's original Y pipe was retained (from the looks of it) and then a pipe welded up to it.
Next time I'm at my computer, I'll see if I can't dig up some horniac pics (longhorn/pontiac...horniac. )
