Old 09-18-2004, 06:11 PM   #1
78SilveradoSWB
78SilveradoSWB's Avatar
Question Electronic Speedometer Question
If one were to convert to Autometer gauges and choose to use the electronic version speedometer vs. the mechanical one, does this eliminate the speedo cable to the tranny? If so, where and how does the speedometer read the speed? A sensor goes somewheres?
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
Old 09-18-2004, 06:40 PM   #2
RockHQ
ROCKET POWER!
RockHQ's Avatar
It does eliminate the speedo cable. You would replace your tramsmission's speedometer drive gear with a magnetic pickup unit, or a VSS sensor and run the wires to your speedometer.
What did i do last nite?
I had a wonderful time,
That's what they tell me
1979 C-10 shortfleet: Olds 350, Th400, 12 bolt
Current project: 1969 Olds 455 W-30, needing a rebuild
RockHQ is offline   Reply With Quote
Old 09-18-2004, 06:56 PM   #3
swervin ervin
You get what you pay for
swervin ervin's Avatar
I don't think so. I think the cable is still used but the speedo has a built in vehicle speed sensor. I asked Autometer about this when I was installing my Pro Comp gauges. At the time they didn't have an electric speedo in Pro Comp's and was told I would need to use the electric Sport Comp if I wanted to use my cruise control. Hooks up the same way as a mechanical gauge.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 09-19-2004, 01:11 AM   #4
cliffsta
Stepsides RULE
cliffsta's Avatar
yeah swerve man is correct. the cable still exists, but instead of the colored gear in the tranny its got a little dillio thingie, its on the 87 models i think. but don't take that as in stone.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 09-19-2004, 04:49 AM   #5
1972C10
1972C10's Avatar
Nah get a full electric gauge .. On that Th-400 you should * be abel to use a vss off an 89 C1500 W/T With 305 And A Th375 Try that it
VEHICLE SPEED SENSOR for a
1989 CHEVROLET TRUCK C1500 1/2TON P/U 2WD
WITH AUTOMATIC TRANSMISSION (Change)
Normal Stock
Not Available
Item Part
No.
Warranty Core
Value Unit
Price Availability
Store Web
WELLS SU1090 3 MO $23.99
TO TEST->LOCATE TEST CHART "SU17" IN WELLS TEST MANUAL
WELLS SU1411 3 MO $109.99
It didnt give me an option to put in Th375 So either the W/T Had it special and vatozone dont have the option in the computer Doubtfull..
Or the 700R-4 And Th-400./375 use the same Vss as the 700 So maybe any 700R4 VSS will work Just make sure to use the proper drive gear to retain correct reading.
Althou i think most automter electric speedos have a recalbration mode.
1972C10 is offline   Reply With Quote
Old 09-19-2004, 04:51 AM   #6
1972C10
1972C10's Avatar
After market makes Vss senders that just hook onto the speedo cable Hookup on the trans. as well as some that still retain cable operation but have wires for Electric VSS as well.
Old 09-19-2004, 04:29 PM   #7
SanitysBane
on all of the factory eletric speedometers that i have seen it was a meatle gear on the output shaft with a magnent sensor and wires running out, no calbe, i've got one sitting around out of a 700R4
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 09-20-2004, 12:33 PM   #8
RockHQ
ROCKET POWER!
RockHQ's Avatar
To put it shortly:
Factory electronic speedometers use a transmission mounted vehicle speed sensors or VSS's. No cables, never. No optical devices either.
Factory mechanical speedometers use a cable. If there's an electronic cruise control it uses a speedometer mounted VSS.
Aftermarket electronic speedometers may use:
1. A factory magnetic induction VSS on the transmission.
2. A conversion kit magnetic VSS that replaces the speedometer cable but is GEAR driven by the transmission output shaft
3. A conversion kit that retains the speedometer cable, the speedometer itself has a VSS output for cruise, abs etc.
When using a magnetic VSS and electronic speedo there are no optional drive "gears" on the transmission. The VSS signal is fed to a buffer, modulated for the proper gearing and tire size and then fed to the speedometer, cruise control and ABS if equipped. If you change rear end gearing or tire size and want the speedo to read correctly you'll need to change that buffer (DRAC or Digital Ratio Adapter Controller is GM lingo for it) or modify the existing one. This is how GM did it, anyway.
So the proper answer to the original question would be:
It depends on whether or not you get a semi-electronic or full electronic speedometer. If the former, see swerve's answer. If the latter, see mine.
Old 09-20-2004, 03:52 PM   #9
78SilveradoSWB
Thumbs up
Thank you all for your respective answers.
Mitch
454 BB, TH400
