Lovin' Life in Miss.!
Did I dun did fargged up?
Well got done with my wiring. Finished the lil details holding me up for the maiden start up of my Goodwrench 350. Fired right up with just a bump. First time one came to life for me with no leaks. It was a good omen. Made extra sure nothing was in immenant danger, ran her for 20 mins at 1900-1950 for cam break-in. Everything as advertised. Bled my brakes this morning, put in the seat. Went for my maiden voyage.....a 1/4 block. Very heavy vibration, slow to accelerate. Then, Oh My God! I realized I had'nt topped of my tranny fluid! It took 2 quarts. Vibration still present after fluid service. Idles fine, have not hooked up a tach to see the range. Suspect it is vibrating between 1100-1700 rpm.
So whatcha think. Did I blow up my tranny?
The truck... you hear that? No really, you did hear that?!!! |
running 2quarts low for a short distance won't harm the tranny
i'd be lookin at motor mounts,torque converter bolts trannymount bolts driveshaft angles proper tv cable adjustment on overdrive trannies etc.
What about runnin the motor at 2 grand for 20 minutes 2 quarts low? Checked tv cable, it's correct. Waitin for it to cool off to check motor mounts and converter bolts. Drive shaft angles out of question since vibration occurs while parked.
All input appreciated.
you didnt hurt the tranny 2 qts low for that short of a time. the vibration could either be something inside the tranny generally a bad torque converter can vibrate. the best thing to do to isolate the vibration is to unbolt the torque converter from the engine and then run it. if the vibration is caused by the tranny it wont be there with the tranny disconnected.give everything a good once over make sure all bolts are tight. another thing to try is to spin the converter and bolt in differently to the flexplate. in other words take out all 3 bolts then spin the converter around so that the next pad on the converter lines up with the hole in the flexplate and try that
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
Unbolted torque converter and ran. Vibration still present. Disconnected serpentine, vibration still present. Suspect harmonic balancer. Bought a Performance Products balancer from the local speed shop. Asked for balancer for externally balanced 350. Kid gave me a balancer labled sbc 400. I questioned the kid repeatedly he finally showed me the catalog. There was no sbc 350 externally balance listed in 6". So I figured ok... Guess this famous Chevy interchange is at work. I haven't put on a new balancer yet, but will today to confirm. Will keep posted. Anyone know fer sure if sbc 400 externally balanced balancer will/will not fit 350?
Rich
you cannot use a 400sbc balancer on a 350 you will blow the motor up from throwing it severely out of balance the 350 is internally balanced and the 400 externally do not run that balancer on that engine
Cableguyo beat me to it.
72 CHEYENNE 10 SUPER 468/400/3.73 |
Thanks. In process of replacing it now. I'm gonna lay into that "speed shop" guy!
Rich
Anyone got a trick for just one guy to break torque/torque down the balancer bolt? Don't have any help and the assembly is rotating. My cheap flex plate wrench isn't long enough to wedge it in place.
All input appreciated. Rich
normally need an impact gun to get the bolt out. and then a balancer puller to get the balancer off. i have never seen anyone get the bolt out without and impact gun
Was leary of using an impact on that bolt. Will fire up the compressor. What about torqing it down? Big fan of torque wrench.
your going to need an impact gun to put the new balancer on as well. because its a press fit and the bolt is what pulls it back but you will never get it back as far as it needs to go by hand
#13 | |
The oddest Todd around
#14 |
True, you do not need air tools to remove the bolt. It's easy enough when the motor is on a stand. You can reach the flexplate and harmonic balancer at the same time. When the motor is installed, you can't and the impact becomes necessary without 2 people. Zipped right out. My non-mechanical neighbor is gonna come over and help me torque it down. Spec calls for 60 foot pounds, I wanna make sure I get it.
Will post how she runs when done. Hope I screwed nothing else up. Thanks for all input! Rich
#15 |
good luck hopefully it didnt run long enough to do any major damage
#16 |
Well, new balancer is on and no vibration!!!! Still gotta hook up torque converter, can't wait for a drive longer than a 1/4 block! Thanks again for all the help. This board is the ...greatest!!!
#17 |
good deal great to hear glad to be able to help ya out
#18 |
Finish the'71..or bust!
I just love a happy ending!
#19 |
Senior Moment
![]() Join Date: Mar 2002
? Is the parts guy still alive ? LOL
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
#20 |
71 DELUX
Glad you were able to get this handled. Sorry the (very small) window of opportunity passed to get out there and assist you. Looking forward to getting out there to see the progress.
Maybe another Sac area board member will want to join me? Keep up the great work!
5/4 drop LWB wood bed - 15x8 front 235/60 - 15x10 rear 295/50 2003 FORD Escape 1998 Honda VTR1000 |
#21 |
Let me know. I am 40 miles northeast of Sacramento in a little town called El Dorado.
I have a 70 Blazer 4x4, a 70 C30 and a 67 C10... |
#22 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Get er back together yet????? Or are you too busy doing burn out's!!!! hope all went well.
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#23 |
blood type; Retumbo
FYI Moroso sells a VERY handy tool for installing balancers. it comes with adaptors to fit about anything out there. if I remember right they are about $40. that way you dont risk hurting the threads in crank or on the bolt. it uses a 1 1/4" wrench & one guy can do it alone.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
#24 |
Vortec in the works
WE WANT PICS
68? It's all figured out untill you get it apart. Is it Sunday yet??? 68 Project 68 SWB frame off/98 Vortec with stock FI/power everything. 95 ECLB 2500 with 346,000 on the clock(the original HD) 99 Lesabre-wifes ride 08 Crew Cab LTZ-All Mine 89 SWB 5/7 drop-Son's first ride. |
#25 |
I happen to have that very tool! It gave me a reason to buy a big honkin crescent wrench to use it.
The parts guy is still walkin, I haven't got over to Tognotti's yet to give em the once for. I've been talkin to some folks that have done business with em that say they are real stingy on returns. I'm gearing up for a fight. Truck is runnin like a raped ape.... Goes real good but has a few vibrations at speed. Need to adjust carb and tv cable. Tranny hunts 3-4 gear pretty bad. Any good tuners out there? I suck at the "feel" stuff. Should be easy for whoever has the talent. Edelbrock 1406 carb & intake, stock HEI dizzy with accel supercoil, stock cam, does have headers though. Hope to post some progress pics real soon. Truck currently in body/paint shop. Looks like they will have it 2 or 3 weeks. Panel wise she is in pretty bad shape. Tons of old mud. Not a propery lined up panel on it. Like I said before, I suck at the feel stuff. So, I gotta pay through the nose. Grendal and SactoC10, I'm hopin to put together a wingding when I get my truck back. I know 3 other guys with 67-72 trucks. Maybe depot park in Rio Linda? Time line is kinda far out. Maybe 3-4 weeks. Jeff, have fun on your LA parts run. Thanks again all for the help. Rich
