09-18-2004, 08:50 PM | #1 |
Under dash Harness F/S
Pulled from a '71 2wd with gauges and heater, non A/C. The only splice work done is one wire at the floor mounted dimmer switch. Everything else is factory original. No melted connections. Includes the washer switch, fuse block with no breaks or cracks. Have most all the electrical hook ups tagged. $15 plus shipping.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
09-19-2004, 11:50 AM | #2 |
67-72 Addict!
Ironhorse, I'm interested if the fuse block terminals are in good condition and not all Rusty. How much to ship to 21237?. Thanks
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
09-19-2004, 06:10 PM | #3 |
70c10, Sent you a PM
