09-18-2004, 11:10 PM | #1 |
Pulling Tranny/drive shaft...have questions,,,need answers please.
Ok, The engine is out and there sits the 3 speed tranny on the cross member, and of course connected to the driveshaft at the u-joints. What is the correct steps removing the tranny and drive shaft. If someone can explain how I should go about this it would make it much easier for me. Thanks in advance.
Alex 1971 Lil' Red 350 SBC 700R4 |
09-18-2004, 11:23 PM | #2 |
Designated A-hole!
Unbolt the driveshaft from the yoke on the rear end (should be 2 u-bolts). If it's a 2 piece drive shaft unbolt the carrier bearing from the crossmember. Then pull the driveshaft out of the back of the tranny (should slip out). If it hasn't been done in a while it may take a some effort to do it.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
09-19-2004, 12:22 AM | #3 |
Still drivin' a Rat Rod
Be sure to support the trans with a jack.The thing is heavy when your lying on your back.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
09-19-2004, 11:09 AM | #4 |
Post Whore
Make sure you take steps for preventing your truck from rolling once you disconnect the driveshaft - that kills someone everyonce in a while - forgetting your truck can start rolling if you are a bit of an incline or unlevel ground.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
09-19-2004, 02:43 PM | #5 |
Thanks Guys! The truck is up on stands...so it cannot roll.
09-19-2004, 07:43 PM | #6 |
Cantankerous Geezer
If all that's holding the tranny up is the crossmember and the driveshaft, put a jack under the tranny before you disconnect the driveshaft.
Now if you're young and in decent shape, you don't need a jack for the 3 speed. Just use the bench press method of installation. I used to put them in and out by myself. You will need two bolts set up as alignment pins. Otherwise it's tough holding the tranny up with one hand and turning the tailshaft with the other while trying to stab it in.
Fred There is no such thing as too much cam...just not enough engine. |
09-19-2004, 08:49 PM | #7 |
I am in good shape but I am going to use a jack anyway. I got caught up in cleaning/degreasing the engine compartment this week end so I never got to the driveshaft and tranny. I do appreciate the tips and help though...I will remove the ds and tranny this week. Thanks Guys!
09-20-2004, 01:58 PM | #8 | |
Cantankerous Geezer
