09-19-2004, 12:12 AM | #1 |
Blue 67
Gasket question:
Hi
I am planning to change my air intake from stock to edlebrook performer series. I also want to change the carb to 4 edlebrook 600 4 bbl. I plan to use felpro gasket for the intake. Do I need to use any sealant/adhesive too? Thanks for info. |
09-19-2004, 12:21 AM | #2 |
Still drivin' a Rat Rod
I always run a small bead of silicon around the water ports,and a thick bead under each end,and throw the rubber gaskets away.Those stupid things always leak.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
09-19-2004, 01:00 AM | #3 |
It is also a good idea to take a punch and go along the valley about every 1/4 inch or so where the rubber or cork gaskets would have been before you lay a thick bead of silicone in there.
Dan |
09-19-2004, 01:35 AM | #4 |
Blue 67
Thaks for the replies, now another questiion;
Any particular brand of silicon? |
09-19-2004, 04:58 AM | #5 |
I only use silicone across the front and the back of the intake vally.. No punching nessacary Gm didnt start beating the blocks with a chisel when they went to silicone across the intake .
I quit putting silicone around the water ports because i never have any leak and when you do put silicone there the gasket slides around I suggest using some print-o-seal Mr gasket intake gaskets they are very effective on aluminum intakes Althou i have used plan blue fel pro with great results And get a little awl or screwdriver and make sure the crack where the heads and vally meet are clean .. i spray mine down with B-12 prior to applying silicone and make sure you get a good bead at that point .. and i put a small dab on the gasket on the corners after i posistion the gasket onto the heads I suggest using Red High Temp Silicone Its all i ever use and ive never had it blow out or leak . Last edited by 1972C10; 09-19-2004 at 05:00 AM. |
09-19-2004, 07:40 AM | #6 |
Old Skool Club
I used the Fel-Pro gaskets that Edelbrock recommended when I installed mine. As for the Silicone, Permatex has one specifically for gaskets. Be cautious with silicone sealers. Some will cause metals to corrode, over time.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
