Old 09-19-2004, 12:47 AM   #1
4bynut
4bynut's Avatar
WTB K20 4x4 (IL)
Thinking of starting a new project. Like the title say's I'm looking for a driver K20 4x4 in or near IL. Would also so be interested in one with decent body, but maybe needing a motor or tranny. Let me know what you have. Thank's Jason.
4bynut is offline   Reply With Quote
Old 09-19-2004, 10:36 AM   #2
ltitsnw
ltitsnw's Avatar
How about a 72, chassis is all done(sand blasted, painted, all bushings, shocks and 2 1/2 inch 4 spring lift also new) has a 70 GMC body, cab has usual rust, fenders and box sides are rust free, doors are trash. Little rust in floor at the back corners. The grill is almost perfect. 350/sm465, dana 44 front, 60 rear, 4.10 gears. new 33-12.5-16.5. engine runs decent but has high miles. $2500 is my bottom dollor. pm me I have picks and I could give you my cell number to talk about it if your interested. Thanks Troy
72 2wd Short Super-almost ready to start on it
95 S10 ZR2-not sure why it followed me home
02 3/4 2wd reg cab-work truck, possible 6.0L donor
06 4x crew-kid hauler, snow chaser
ltitsnw is offline   Reply With Quote
Old 09-20-2004, 06:42 PM   #3
4bynut
4bynut's Avatar
Re: K20
ltitsnw; PM sent
Old 09-21-2004, 06:23 PM   #4
4bynut
4bynut's Avatar
Ttt
Old 09-22-2004, 07:05 PM   #5
4bynut
4bynut's Avatar
LTITSNW, 72ADDICT, LASH, sent you all PM'S with no response. I'm not sure if your not getting them. But in case your not my email is <jayj@starband.net>. Thank's for the response's Jason.
Old 09-22-2004, 07:27 PM   #6
ltitsnw
ltitsnw's Avatar
Sorry guys, have alot going right now and I don't get alot of time for the computer, I'll try to get current pics of the truck tonight and throw them on here........Thanks Troy
Old 09-22-2004, 10:04 PM   #7
see ten
WTB this ad
see ten's Avatar
Here is a link to my brother's k20 That I am trying to help him sell. The truck is in NW Georgia.
http://home.earthlink.net/~a71-c75/
see ten is offline   Reply With Quote
Old 09-23-2004, 01:36 AM   #8
chevycamaro1981
I just listed a 1/2 ton 4x4 stepside with fresh paint...not rust...needs motor...very sweet truck...in Illinois...I have pics.....I also can get 3/4 ton axles....
chevycamaro1981 is offline   Reply With Quote
Old 09-23-2004, 01:36 AM   #9
chevycamaro1981
I'm from Rock Falls...I see your from sterling...
Old 09-29-2004, 02:16 PM   #10
4bynut
4bynut's Avatar
BTTT...
Old 09-29-2004, 10:18 PM   #11
john@thepier
john@thepier's Avatar
What is your budget {in other words how much do you have to spend,this would help us in helping you.and don't tell us as little as possible.be realistic and someone here will more than likely have or find you a ride. JOHN
john@thepier is offline   Reply With Quote
Old 09-30-2004, 08:51 AM   #12
72chey4x4
I've got a 72 K/20 4x4 For Sale in Indiana
The body was pulled, frame cleaned up and coated. New 6" Skyjacker soft ride suspension with pitman arm changed, new shocks, and stainless extended brake lines. Runs on 35x14.5-15 Thornbirds mounted on Eaton rims. Truck is very solid the cab corners, rockers, and body mounts are all great. Currently in grey primer with minor body work required before paint... rear fender well patch pannels were proffesional installed and roughed in. The truck is powered by a healthy 350 with HEI ignition and transmits the power through a rebuilt turbo 350 and rebuilt NP205. I just completely rebuilt the Eaton Ho52 rear end it has 4.10 gear and a Detroit no-spin (l set the lash at .008). To my knowledge the front is an open diff dana 44... it has new hub bearings and seals which I installed just after rebuilding the rearend.
I have a new Goodmark drivers side door and good passengers door. Driver's side fender is goodmark. Could use a new passengers side fender, or you could clean up the one that's on it (no rust, but needs some attention).
I haven't had the truck very long, but have driven it about 500 miles since completing all major work to make sure there aren't any problems with it. I have every thing you need to finish the truck. I would suggest buying new wiring harnesses to eliminate a few shorts. The truck also has the remains of a dealer installed A/C kit.
I'm asking 5,000 obo.
72chey4x4 is offline   Reply With Quote
Old 09-30-2004, 02:12 PM   #13
4bynut
4bynut's Avatar
Thank's for the reply 724x4. But I've only got about $2000 to spend right now. Wish I had more though. Thank's Jason.
