Old 09-19-2004, 11:17 AM   #1
Yukon Jack
Post Whore
Yukon Jack's Avatar
NP205 floor clearance
I just swapped in an NP205 into my 70 K5 - the prior owner said it had a Dana 20. I have all new rubber body mounts and I am using polyurethane transfer case mounts, the ones that are used to attach the adapter to the crossmember.
The NP205 is just barely touching the bottom of the K5's floor. I have not been able to torque down the bolts going through the crossmember to the adapter but I doubt that will pull the NP205 down much. I need to move the crossmember back approximately 3/8" to make it so I can bolt the adapter to the crossmember.
What kind of clearance do you all have between your floor and your transfer case?
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-19-2004, 01:40 PM   #2
skid
The closest point of touching is about 1.5" where the body brace goes across the vehicle near the transfer case out put shaft. Everywhere else is inches.
Toys:
72 K5 Blazer
74 Vette
skid is offline   Reply With Quote
Old 09-19-2004, 02:18 PM   #3
Yukon Jack
Post Whore
Yukon Jack's Avatar
Wow, I assumed the crossmembers were the same but it doesn't sound like it.
Old 09-19-2004, 03:30 PM   #4
skid
The body brace is part of the body, not the frame. It is part of the body's reinforcement, and is just behind the removeable shifter plate. Mine's a 72.
Toys:
72 K5 Blazer
74 Vette
Old 09-19-2004, 05:41 PM   #5
Blazer1970
Blazer1970's Avatar
I know for a fact that the 205 crossmember has about an inch more drop than the Dana 20 crossmember.
Blazer1970 is offline   Reply With Quote
Old 09-19-2004, 06:29 PM   #6
Yukon Jack
Post Whore
Yukon Jack's Avatar
That would explain it then, I will just use some spacers to drop it down to that level than. Thanks.
