Old 09-19-2004, 04:57 PM   #1
Als454
Need HEI Harness!
I need the pigtail that plugs into the HEI cap. The one for the Batt and Tach terminals. I was hoping someone would have one they cut from a wiring harness. Thanks
72 Chevy A/C P/B P/S Tilt
454 Engine 400 TCI Trans
C30 Frame C10 Suspension
Short Wheel Base (Dually)
Als454 is offline   Reply With Quote
Old 09-19-2004, 07:04 PM   #2
71swb4x4
71swb4x4's Avatar
You can use the cheap female spade plugs that you can get at any wal-mart or hardware store.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-19-2004, 07:08 PM   #3
71swb4x4
71swb4x4's Avatar
Something like this is what I used.
Old 09-19-2004, 09:35 PM   #4
Als454
Yeah, I'm using those now, I just though if I could get the correct connector it would look alot cleaner.
Old 09-20-2004, 01:29 PM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Summit sells them.
Old 09-20-2004, 03:48 PM   #6
poff
GM# 12167658
Pace Performance has factory pigtails. They are kind of expensive but stock.
http://www.paceperformance.com/index...D&ProdID=84486
A little cheaper at Sallee Chevrolet:
http://www.sallee-chevrolet.com/Dist...rts/index.html
'70 K-20 San Diego, CA
poff is offline   Reply With Quote
