Keep On Truckin'
Gas door with remote release
Cut out the gas door pocket assembly from a 1990 Mazda 626 and welded it into the driver's bed side. It's a remote release door which means a flat fuel door with no finger notch. The filler neck from the same car worked nicely after a couple of cuts and welds to the required configuration. Now, all I have to do is weld up the box pieces I cut out to hide the filler neck in the bed. Fuel Cell Guy aluminum tank tucks nicely under the bed.
Just Passin' Thru Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire..... |
![]() Join Date: Mar 2003
looks really nice. Do you have a pic of the remote release?
#3 | |
Keep On Truckin'
No, I didn't take a picture of the remote release. The mechanism actually has two release levers; one for the fuel door and one for the trunk. I plan on using the one for the trunk as the hood release. I still have a ways to go with the truck so I haven't worked out all the details just yet on where to mount the release mechanism in the cab.
PROJECT 7DEUCE
![]() Join Date: Dec 2002
That's a pretty slick set-up keep us posted on the final location of the release lever..
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
