Old 09-19-2004, 07:57 PM   #1
Russell
Professional Grade
Russell's Avatar
Sending Unit Question
Hey guys!
I just installed a blazer tank into my truck, but to use the skid plate, I was forced to mount the tank at a slight angle, with the tank being higher in the front than in the back. Anyways, I need to fix the inaccurate reading my gauge is giving me now. What I need to know is what resistance I should be getting with an empty tank. Then I can add a resistor / capaciator as needed to adjust the signal the tank is sending me, I don't really care if my sending unit goes over the full mark, I just want it to be a bit under the empty when it is running empty so I don't run outta gas...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 09-19-2004, 09:40 PM   #2
SanitysBane
its 0 empty, 90 full on my 83, the 88 is 0 empty 100 full
'96 Nissan Pathfinder
'02 Firebird Trans Am.
'88 K5 Blazer
SanitysBane is offline   Reply With Quote
Old 09-19-2004, 09:44 PM   #3
Russell
Professional Grade
Russell's Avatar
Thanks man!
Old 09-19-2004, 09:44 PM   #4
SanitysBane
no problem, im here to help, and get help
'88 K5 Blazer
