Old 09-19-2004, 09:41 PM   #1
c-1072
Question Keep It Or Swap It Out !
Hey guys i am building my short box 4x4 and i am going with a throttle body 700r4 set up . My question is do i stick with the close nuckle front axle or do i swap the axles for the ones in my 89 blazer doner . Just keep in mind its just a daily driver . I dont have any expierence with the close nucle type , are they rare or lust junk . thanks undefined
c-1072 is offline   Reply With Quote
Old 09-20-2004, 04:06 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I would swap em out just to run newer better axle's and disk brake's ... BTW I did not know that 72's came with the closed knuckle axle???
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 09-20-2004, 09:11 PM   #3
1969 GMC
1969 GMC's Avatar
If you're gonna upgrade it, might as well add discs. your 10 bolt will have metric brake fittings vs SAE on the truck, but other than that it should work ok.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 09-20-2004, 11:50 PM   #4
c-1072
YA to honest i have no idea what year the frame is . The truck is one im completely building from the ground up . Not to many nice ones around new york state .
