Old 09-20-2004, 08:06 AM   #1
1972C10
1972C10's Avatar
Installing New Vent Window Seals?
Never done this before any suggestions? Its on my 85 I bougt new seals from LMC and no instructions .
1972C10 is offline   Reply With Quote
Old 09-20-2004, 01:54 PM   #2
Jonboy
Slots go on anything!
I tried to install the same seals, and they looked terrible. I ended up going to the pick-a-part and getting a set of vent windows with good rubber. Sorry this might not help, but that is what I had to do. That being said, I spent the better part of an afternoon wrestling with one side.
1974 Jimmy- 5.3/4L80e/NP241
Old 09-20-2004, 08:59 PM   #3
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
Vent window seals
I went the easy route and purchased the whole vent window assemblies for both sides, was much easier than messing with the seals only. The cost was about $150 a side, got them from a local chevy trucks parts dealer here in Houston, but I know LMC sells them
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 09-21-2004, 06:04 AM   #4
1972C10
1972C10's Avatar
Yeah I have eyeballed the entire assemblys but surely there is a trick to installing these seals? Id hate to think i wasted my money on something that cant be installed.
Old 09-21-2004, 07:02 AM   #5
jpaitala
Custom Truck, here I come
jpaitala's Avatar
Check out: http://www.hillmanimages.com/912/window_seal2.html
There's some sort of an instructions, even it's not for chevy pickup...
But the window system is quite similar.
Check out my homepage!!!
-'74 Cadillac Eldorado
-'00 Ford SuperDuty 7.3
jpaitala is offline   Reply With Quote
Old 09-21-2004, 11:07 AM   #6
Nvbowtie
Nvbowtie's Avatar
check a few glass shops, got mine installed for 50 bucks
www.unlimited2u.com/chevy
1980 Chevy C-10 Silverado
1988 Chevy Blazer Tahoe
Nvbowtie is offline   Reply With Quote
Old 09-21-2004, 01:38 PM   #7
MidnightBlues
Did it half a year ago.It's not that difficult. The only pain in the a.. is to get the seal into the metal frame.That will take at least an hour.And don't forget to lubricate the seal very well, otherwise it's impossible.
Also you need to remove the rivet from the hinge and order a new rivet.
If you need some specific help,just pm me.
Good luck.
*Andre*
1984 C10 SWB, 350/700R4
MidnightBlues is offline   Reply With Quote
Old 09-21-2004, 02:50 PM   #8
cobra1
I got a set of seals for my 74 c10. When I got out the vent window I found that to replace the seals you will have to grind out the rivets. This make it possible to install the seals. A small job that became a large job. I used pop rivet gun to replace rivets.
cobra1 is offline   Reply With Quote
Old 09-22-2004, 01:58 AM   #9
1972C10
1972C10's Avatar
I have pop rivets if they will work .. If not where did you get the rivets from?
Old 09-22-2004, 09:17 AM   #10
MidnightBlues
Pop rivets will work, but I got the original rivets from LMC.Just to keep things as original as possible.
*Andre*
Old 09-22-2004, 03:11 PM   #11
screwballl
Tonawanda 454
screwballl's Avatar
... or the local Ace Hardware should have them, thats where i get all my rivets and odd parts/pieces
91 Chevy Suburban Tonawanda 454 R2500 - SOLD!!!
04 Dodge Durango 5.7L Hemi 2WD, 24K miles (as of July 2011)
In the past 30 years about 90% of Fords are still on the road, the other 10% made it home.
screwballl is offline   Reply With Quote
