Old 09-20-2004, 02:57 PM   #1
garthdader
Np 205 Help!!
Two questions.
1) Does anyone know the shift pattern for the NP 205 transfer case???
2) Any time I turn hard (when in 4wd) I heard a tapping sound. It speeds up and gets louder and I go faster and vice versa for slower. I checked the axle knuckles and there is clearance. I had just installed new hubs, rotors, bearings, and calipers. Any ideas??? This can't be normal.
garthdader is offline   Reply With Quote
Old 09-20-2004, 04:21 PM   #2
MAC67
" SHOW ME"
MAC67's Avatar
your 205 pattern is ,,, there are 4 positions on it , from back to forward , all the way back is 4 hi , next is 2 hi , next is nuetral and all the way forward is 4 lo ,, on your clanking problem it could be a number of things , bad axle joints , check your front drive shaft for slop , sounds to me like your axle joints need replacing , but you also could have something messed up in your new bearings or hubs , maybe you overtightened or something , but id go for the axle joints
MAC67 is offline   Reply With Quote
Old 09-20-2004, 04:41 PM   #3
GMC71k20
mac, what kind of steering set up do you have on your blazer? hows that deuce of yours doing?
GMC71k20 is offline   Reply With Quote
Old 09-20-2004, 10:25 PM   #4
wildwood
wildwood's Avatar
Anytime I turn sharp with the hubs locked I get a clunking noise too. I have new joints and it still occurs. I beleive that some noise while turning sharp with the hubs locked is normal. The hubs shouldn't be locked when driving on dry pavement. When driving in mud, dirt, ice, or snow the light clunking noise will dissapear. I do have a very strong Power-Lok LS diff in the front of my truck if that makes any difference. If you wanted to see if it's the drive shaft, try removing it and try it then.
You can't get out if ya don't get in
wildwood is offline   Reply With Quote
Old 09-21-2004, 05:39 AM   #5
MAC67
" SHOW ME"
MAC67's Avatar
sharp truck wildwood!!! , im just running a dropped drag link and a raised steering arm , id like to do cross over but i havnt researched it enough yet to do it , i am still hashing out the deal on the deuce , ill keep ya posted
Old 09-21-2004, 02:47 PM   #6
stan79chevy
stan79chevy's Avatar
i had the same clunking sound when in 4wd
i tracked down to a grease zerk on the driveshaft was ticking on the exhast. i just took the grease fitting out and put in a little plug
stan
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
