![]() Join Date: May 2002
Wanted: Power Steering Bracket
I've got the bottom bracket for a '69 small block, but the other one is shot. Anyone have the top bracket that I would be able to get from them? Please let me know. Thanks
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
Watch out for your cornhole !
![]() Join Date: Jun 2003
There is no top and bottom bracket on a small block p/s. The brackets cradle the pump as a unit.
Could you post a picture, or, more details?
With the pictures not working correctly, I'll try to explain more. Basically, all I have is the bracket that the pump sits in. I don't have the bracket that puts tension onto the belt. From what I can tell, there are two bolts on the back of the pump, and one on the front. The bottom two (the one in front and one in back are lined up) are the only spot where the pump "sits." Then there is the tension bolt that is up higher on the pump. I don't have the bracket that that bolt goes into.
Cantankerous Geezer
Here's a link to a pic I just took of my 69's power steering bracket, I don't know if it's correct, but it does work with headers. It bolts to the motor mount. Someone else was looking for a bracket for headrs, but I can't find the post.
Fred There is no such thing as too much cam...just not enough engine. ![]() Last edited by Fred T; 09-21-2004 at 11:29 AM. |
That looks like the one that I'm looking for Fred. Does anyone have that one, and would like to get rid of it?
Cantankerous Geezer
ttt
Fred There is no such thing as too much cam...just not enough engine. ![]() |
Senoir Member
There is a set on ebay....item # 7923410812. Greg
67 Chevy, Small back glass, Factory 4WD, Factory Shortbed, Factory V8, Lifted 4" 70 GMC Sierra Grande, Factory Shortbed, Factory 402/400 turbo, Super Custom Interior. Numbers matching with SPID & Build Sheet. 68K Original Miles. Restored 2010 70 GMC Restoration Pictures http://67-72chevytrucks.com/gallery/...00&ppuser=4424 |
