WTB this ad
69 custom camper k20 for sale
Howdy, I have a 69 K20 that needs a good home! The truck is a fact air truck that needs the compressor reinstalled to be functional. It has a 2.5 inch suspension lift and a set of 16 inch alloy wheels with fresh all terrain tires. The front brake pads and calipers are new. Running gear has been converted to a GM 14 bolt rear and a Dana 44 front with disc. Gearing in the axles is 4.11 . The motor is fresh with all new bearings and a comp cams 4x4 camshaft. The carb has also been recently replaced. The truck has a granny 4 speed that was recently went through with all new bearings and gears. The exhaust is also fresh with 2.5 inch pipe and 2 chamber flowmasters. The truck is very functional and reliable, however it is not pretty! The body is on the rough side and the windshield is cracked. This shouldn't be a problem if you are looking for a functional chassis. If you are looking for one to restore this might not be your truck. Much time has been spent on the running gear of this truck and I hate to see it go but a divorce and changing needs forces its sale. The truck belongs to my brother and he hasn't brought me any pictures of it. If anyone is interested I could probably post pics in a day or so. He really needs to see $2200 out of the pickup, much more than has been spent to bring it to where it is now.
Thanks Try this link for pictures http://home.earthlink.net/~a71-c75/ Last edited by see ten; 09-22-2004 at 02:51 AM. Reason: Add link to pictures |
member #16
![]() Join Date: Dec 1999
Welcome to the board. It would help to go to user CP and edit profile with location. John
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
K 20
Where is it , let me see the pics
#4 | |
WTB this ad
If it helps the truck isn't so much beat up as rusty. Previous owner has put filler in the rockers and corners, there are tiny rust holes above the windshield on the inside. The cab floor shows sign of patching where it meets the kick panels. Drivers door is broken/ripped(?) at the top hinge. The bed doesn't seem to show signs of rust but does have filler in one side where a dent was repaired. Of course it's gone under the battery on the passenger side. According to the build sheet it was a factory tach truck but the previous owner has robbed it. My brother had planned on replacing the cab and front clip with better parts. Due to his divorce he really needs to find the truck a home. If you don't mind the rust this a very functional and reliable truck. I will do my best to get some pics posted by tomorrow. Thanks for taking the time to reply. |
WTB this ad
Link to pictures has been added to first post.
WTB this ad
I may drive the truck to the cruise-in in Cleaveland Tennessee this weekend if anyone is going to be in the area.
WTB this ad
Any offers? My brother in law has a trailer big enough to haul this beast and said he would move it for reasonable $.
